I've added some tests to the test suite (both in the trunk and 1.4.x) but they're not showing up in the nightlies - one of them should fail with the current code, and I've searched the summary files and they are not being run. The file in /home/MPI/testing/mpich2/mpich2 claims to be version 1.4rc1 , but I've verified that this doesn't include the new tests . Until those tests run, I won't know whether the C++ changes are acceptable to the compilers in our test environment. Also, this doesn't appear to have the new C++ or Fortran90 binding code, so that isn't being testing either (and that may change the ABI for C++ and Fortran90, so tests are essential). Am I checking code into the wrong place? Bill William Gropp Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
The nightlies are currently running 1.4 not 1.4.x. I think Pavan picks stuff from 1.4.x that will go into the upcoming 1.4 release. If these tests need to be in the release, let him which ones they are. Rajeev On Mar 23, 2011, at 8:15 AM, William Gropp wrote:
Bill
Oops, can you move them back to 1.4.x. After Bill pointed out that some more changes need to go into 1.4, I forgot to ask you to do that. On 03/23/2011 09:07 AM, Rajeev Thakur wrote:
Rajeev
Bill
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
OK, I have switched to 1.4.x and restarted the tests. On Mar 23, 2011, at 9:07 AM, Pavan Balaji wrote:
Rajeev
Bill
Rajeev
I've added some tests to the test suite (both in the trunk and 1.4.x) but they're not showing up in the nightlies - one of them should fail with the current code, and I've searched the summary files and they are not being run. The file in /home/MPI/testing/ mpich2/mpich2 claims to be version 1.4rc1 , but I've verified that this doesn't include the new tests . Until those tests run, I won't know whether the C++ changes are acceptable to the compilers in our test environment. Also, this doesn't appear to have the new C++ or Fortran90 binding code, so that isn't being testing either (and that may change the ABI for C++ and Fortran90, so tests are essential). Am I checking code into the wrong place?
Bill
The bcastlength test is failing in 1.4.x. Others seem to be working. On Mar 23, 2011, at 9:19 AM, Rajeev Thakur wrote:
Rajeev
Bill
"svn info" in /home/MPI/testing/mpich2/mpich2 shows which branch (or trunk) is used for the nightlies. Rajeev On Mar 23, 2011, at 8:15 AM, William Gropp wrote:
Bill
participants (3)
Pavan Balaji -
Rajeev Thakur -
William Gropp
