Fwd: [mpich-discuss] Problem using mpi_type_create_f90_integer
Is this related to the earlier bug report from Cray about type_create_f90 stuff? Rajeev Begin forwarded message:
From: Thomas Jahns <[email protected]> Date: December 14, 2011 7:33:39 AM CST To: [email protected] Subject: [mpich-discuss] Problem using mpi_type_create_f90_integer Reply-To: [email protected]
Hello,
I'm having some problems when using mpi_type_create_f90_integer, where, for 8 byte integers (i.e. requesting 18 decimal places), I get an immediate error for and for 4 byte integers I get a later segmentation-fault when committing a struct type containing the result of mpi_type_create_f90_integer, both bugs happen with the current Intel Fortran compiler 12.1.0 20110811 and NAG Fortran Compiler Release 5.2(747) (with gcc 4.6.1 host compiler for the NAG).
The below example exhibits both problem when run after compilation with defining either WITH_BUG1 or WITH_BUG2.
In the case of WITH_BUG1 I get:
$ ~/opt/mpich2-1.4.1p1-nag52-x64-linux/bin/mpif90 -fpp -DWITH_BUG1 bug.f90 NAG Fortran Compiler Release 5.2(747) Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/mpif.h, line 479: Byte count on numeric data type detected at *@8 Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/mpif.h, line 492: Byte count on numeric data type detected at *@8 Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/mpif.h, line 493: Byte count on numeric data type detected at *@8 Warning: bug.f90, line 44: Unused external reference MPI_WTICK detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference PMPI_WTICK detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference PMPI_WTIME detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference MPI_WTIME detected at TEST_F90INT@<end-of-statement> [NAG Fortran Compiler normal termination, 7 warnings] $ ./a.out Fatal error in MPI_Type_create_f90_integer: Other MPI error, error stack: MPI_Type_create_f90_integer(117): MPI_Type_create_f90_int (range=14) failed MPI_Type_create_f90_integer(97).: No integer type with 14 digits of range is avaiable
The second bug manifests itself in a segmentation fault I've traced to dlp being invalid in MPID_Segment_init.
$ ~/opt/mpich2-1.4.1p1-nag52-x64-linux/bin/mpif90 -fpp -DWITH_BUG2 bug.f90 NAG Fortran Compiler Release 5.2(747) Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/mpif.h, line 479: Byte count on numeric data type detected at *@8 Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/mpif.h, line 492: Byte count on numeric data type detected at *@8 Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/mpif.h, line 493: Byte count on numeric data type detected at *@8 Warning: bug.f90, line 44: Unused external reference MPI_WTICK detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference PMPI_WTICK detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference PMPI_WTIME detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference MPI_WTIME detected at TEST_F90INT@<end-of-statement> [NAG Fortran Compiler normal termination, 7 warnings] $ gdb ./a.out GNU gdb (GDB) 7.0.1-debian Copyright (C) 2009 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-linux-gnu". For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>... Reading symbols from /home/tjahns/bug-reporting/mpich2-mpi_type_create_f90_integer_problem/a.out...done. (gdb) r Starting program: /home/tjahns/bug-reporting/mpich2-mpi_type_create_f90_integer_problem/a.out [Thread debugging using libthread_db enabled]
Program received signal SIGSEGV, Segmentation fault. MPID_Segment_init (buf=0x0, count=<value optimized out>, handle=-1946157051, segp=0x703da0, flag=<value optimized out>) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/segment.c:173 173 DLOOP_Stackelm_load(elmp, dlp, 0); (gdb) bt #0 MPID_Segment_init (buf=0x0, count=<value optimized out>, handle=-1946157051, segp=0x703da0, flag=<value optimized out>) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/segment.c:173 #1 0x000000000045e5ed in DLOOP_Dataloop_create_flattened_struct (count=2, blklens=0x703d7c, disps=0x703d88, oldtypes=0x703d70, dlp_p=0x6d63b0, dlsz_p=0x6d63b8, dldepth_p=0x6d63bc, flag=0) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/dataloop_create_struct.c:581 #2 MPID_Dataloop_create_struct (count=2, blklens=0x703d7c, disps=0x703d88, oldtypes=0x703d70, dlp_p=0x6d63b0, dlsz_p=0x6d63b8, dldepth_p=0x6d63bc, flag=0) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/dataloop_create_struct.c:244 #3 0x000000000045b91b in MPID_Dataloop_create (type=-1946157050, dlp_p=0x6d63b0, dlsz_p=0x6d63b8, dldepth_p=0x6d63bc, flag=0) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/dataloop_create.c:279 #4 0x0000000000416b72 in MPID_Type_commit (datatype_p=0x7fffffffc5e4) at ../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/mpid_type_commit.c:43 #5 0x000000000040dd7a in MPIR_Type_commit_impl ( datatype=<value optimized out>) at ../../../../mpich2-1.4.1p1/src/mpi/datatype/type_commit.c:43 #6 0x000000000040df4b in PMPI_Type_commit (datatype=0x7fffffffc5e4) at ../../../../mpich2-1.4.1p1/src/mpi/datatype/type_commit.c:114 #7 0x000000000040d849 in pmpi_type_commit_ (v1=<value optimized out>, ierr=0x7fffffffc5e8) at ../../../../mpich2-1.4.1p1/src/binding/f77/type_commitf.c:190 #8 0x000000000040d609 in main (argc=1, argv=0x7fffffffc6d8) at bug.f90:24 (gdb)
If any extra information might be useful, I'll be happy to provide.
Regards, Thomas -- Thomas Jahns DKRZ GmbH, Department: Application software
Deutsches Klimarechenzentrum Bundesstraße 45a D-20146 Hamburg
Phone: +49-40-460094-151 Fax: +49-40-460094-270 Email: Thomas Jahns <[email protected]>
_______________________________________________ mpich-discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Probably - I looked into the problem and the problem evidences itself in the datatype code. Whether the bug is there or in the F90 code that creates the types isn't clear. Bill On Dec 14, 2011, at 2:09 PM, Rajeev Thakur wrote:
Rajeev
Hello,
$ ~/opt/mpich2-1.4.1p1-nag52-x64-linux/bin/mpif90 -fpp - DWITH_BUG1 bug.f90 NAG Fortran Compiler Release 5.2(747) Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/ mpif.h, line 479: Byte count on numeric data type detected at *@8 Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/ mpif.h, line 492: Byte count on numeric data type detected at *@8 Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/ mpif.h, line 493: Byte count on numeric data type detected at *@8 Warning: bug.f90, line 44: Unused external reference MPI_WTICK detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference PMPI_WTICK detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference PMPI_WTIME detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference MPI_WTIME detected at TEST_F90INT@<end-of-statement> [NAG Fortran Compiler normal termination, 7 warnings] $ ./a.out Fatal error in MPI_Type_create_f90_integer: Other MPI error, error stack: MPI_Type_create_f90_integer(117): MPI_Type_create_f90_int (range=14) failed MPI_Type_create_f90_integer(97).: No integer type with 14 digits of range is avaiable
$ ~/opt/mpich2-1.4.1p1-nag52-x64-linux/bin/mpif90 -fpp -DWITH_BUG2 bug.f90 NAG Fortran Compiler Release 5.2(747) Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/ mpif.h, line 479: Byte count on numeric data type detected at *@8 Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/ mpif.h, line 492: Byte count on numeric data type detected at *@8 Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/ mpif.h, line 493: Byte count on numeric data type detected at *@8 Warning: bug.f90, line 44: Unused external reference MPI_WTICK detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference PMPI_WTICK detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference PMPI_WTIME detected at TEST_F90INT@<end-of-statement> Warning: bug.f90, line 44: Unused external reference MPI_WTIME detected at TEST_F90INT@<end-of-statement> [NAG Fortran Compiler normal termination, 7 warnings] $ gdb ./a.out GNU gdb (GDB) 7.0.1-debian Copyright (C) 2009 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-linux-gnu". For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>... Reading symbols from /home/tjahns/bug-reporting/mpich2- mpi_type_create_f90_integer_problem/a.out...done. (gdb) r Starting program: /home/tjahns/bug-reporting/mpich2- mpi_type_create_f90_integer_problem/a.out [Thread debugging using libthread_db enabled]
Program received signal SIGSEGV, Segmentation fault. MPID_Segment_init (buf=0x0, count=<value optimized out>, handle=-1946157051, segp=0x703da0, flag=<value optimized out>) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/ segment.c:173 173 DLOOP_Stackelm_load(elmp, dlp, 0); (gdb) bt #0 MPID_Segment_init (buf=0x0, count=<value optimized out>, handle=-1946157051, segp=0x703da0, flag=<value optimized out>) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/ segment.c:173 #1 0x000000000045e5ed in DLOOP_Dataloop_create_flattened_struct (count=2, blklens=0x703d7c, disps=0x703d88, oldtypes=0x703d70, dlp_p=0x6d63b0, dlsz_p=0x6d63b8, dldepth_p=0x6d63bc, flag=0) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/ dataloop_create_struct.c:581 #2 MPID_Dataloop_create_struct (count=2, blklens=0x703d7c, disps=0x703d88, oldtypes=0x703d70, dlp_p=0x6d63b0, dlsz_p=0x6d63b8, dldepth_p=0x6d63bc, flag=0) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/ dataloop_create_struct.c:244 #3 0x000000000045b91b in MPID_Dataloop_create (type=-1946157050, dlp_p=0x6d63b0, dlsz_p=0x6d63b8, dldepth_p=0x6d63bc, flag=0) at ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/ dataloop_create.c:279 #4 0x0000000000416b72 in MPID_Type_commit (datatype_p=0x7fffffffc5e4) at ../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/ mpid_type_commit.c:43 #5 0x000000000040dd7a in MPIR_Type_commit_impl ( datatype=<value optimized out>) at ../../../../mpich2-1.4.1p1/src/mpi/datatype/type_commit.c:43 #6 0x000000000040df4b in PMPI_Type_commit (datatype=0x7fffffffc5e4) at ../../../../mpich2-1.4.1p1/src/mpi/datatype/type_commit.c:114 #7 0x000000000040d849 in pmpi_type_commit_ (v1=<value optimized out>, ierr=0x7fffffffc5e8) at ../../../../mpich2-1.4.1p1/src/binding/f77/type_commitf.c:190 #8 0x000000000040d609 in main (argc=1, argv=0x7fffffffc6d8) at bug.f90:24 (gdb)
Phone: +49-40-460094-151 Fax: +49-40-460094-270 Email: Thomas Jahns <[email protected]> _______________________________________________ mpich-discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
<mpich2-1.4.1p1-nag52.log.bz2><bug.f90>
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
That's a good guess. Was anything done re: the prior bug? -- Rob On Dec 14, 2011, at 2:09 PM, Rajeev Thakur wrote:
Rajeev
Hello,
Phone: +49-40-460094-151 Fax: +49-40-460094-270 Email: Thomas Jahns <[email protected]> <mpich2-1.4.1p1-nag52.log.bz2><bug.f90>
Not yet. It's on my (rather long) TODO list still. -Dave On Dec 14, 2011, at 2:39 PM CST, Rob Ross wrote:
Rajeev
Hello,
participants (4)
Dave Goodell -
Rajeev Thakur -
Rob Ross -
William Gropp
