Hello, Could you explain why configure substitutes the 'DOUBLE PRECISION' to 'REAL*8' declaration of MPI_WTIME, MPI_WTICK into mpif.h and mpi_base.f90? It has been changed into mpich2-1.0.8. I'm asking about it because the MPI-2 says that it should be declared as DOUBLE PRECISION. Thank you. -- Best regards, Yury Kiryanov phone: 8-83130-70700 (ext. 2531) i-net : 8313-2531 e-mail: [email protected] -------------------------------------------------------------------- Closed Joint Stock Company Intel A/O Registered legal address: Krylatsky Hills Business Park, 17 Krylatskaya Str., Bldg 4, Moscow 121614, Russian Federation This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
It does this for systems that allow the use to change the lengths of the basic types in Fortran. This is a (IMHO) terrible hack, but quite a few applications use it. MPICH makes this change *only* when it knows that DOUBLE PRECISION is the same size as REAL*8 . This makes a difference on IBM systems, for example, where the xl compiler has an option to change the size of DOUBLE PRECISION, but that option does not change the size of explicit-sized types such as REAL*8. Bill On Feb 12, 2010, at 3:47 PM, Kiryanov, Yury wrote:
Hello,
Could you explain why configure substitutes the ‘DOUBLE PRECISION’ to ‘REAL*8’ declaration of MPI_WTIME, MPI_WTICK into mpif.h and mpi_base.f90? It has been changed into mpich2-1.0.8. I’m asking about it because the MPI-2 says that it should be declared as DOUBLE PRECISION.
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies. <ATT00001..txt>
William Gropp Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
participants (2)
Kiryanov, Yury -
William Gropp
