Dear MPICH2 developers, I have a problem when I used MPICH2 in win xp 64 bit system, the error is that ‘launch failed: create process <my executable file>’ on ‘my computer name’ failed, error 2 – the system cannot find the file specified.’ Here I listed what I have done when I ran the code as follows; 1, I downloaded the mpich2-1.3.2p1-win-x86-64.msiand installed it successfully; 2, I added the ‘C:\Program Files\MPICH2\bin’ into the paths of user variables and system variables under environmental variables page of my computer properties; 3, I used the VS 2005 and Intel visual Fortran10.1 to compile my code under win x64 (in fact I tried to do it under win 32, I found a lot of unsolved external links), in this process, I have added ’C:\Program Files\MPICH2\include’ to the include path, ‘C:\Program Files\MPICH2\lib’ to the lib path and fmpich2.lib to the link command; and I generated the executable file correctly, 4, I use command window to run it in this way: ‘mpiexec –n 4 <**.exe> ‘,then I met the error as I mentioned. In fact, I have tried open MP installer, I failed with other error, and I also tried smpd –install/uninstall, but not working. I also tried to select the ‘port’ under the configurable settings, but I can not apply it. I really hope you may give me some help, thanks very much. Best wishes, Zhangping Wei
participants (1)
Zhangping Wei
