Re: [MPIWG Fortran] [mpiwg-p2p] FP16 16-bit-floating-point
16 Jun
16 Jun
'17
12:35 p.m.
First, I want to remeber to Takahiro's answer aboout C. > http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2016/p0192r0.pdf > http://www.open-std.org/jtc1/sc22/wg14/www/docs/n2016.pdf They will probably add - short float, and - float16_t, float32_t, float64_t to the C Standard. For Fortran, the MPI standard currently supports floating points through - MPI_REAL for REAL - MPI_DOUBLE_PRECISION for DOUBLE PRECISION and only when supported by the Compiler (i.e. optional) - MPI_REAL2 for REAL*2 - MPI_REAL4 for REAL*4 - MPI_REAL8 for REAL*8 - MPI_REAL16 for REAL*16 The question is, whether Fortran will add something similar as "short float". Another question is, whether we never detected that Fortran has officially byte- or bit-sized floats, like the REAL*8. Rolf ----- Original Message ----- > From: "Kawashima, Takahiro" <[email protected]> > To: "MPI WG Point To Point Communications working group" <[email protected]> > Cc: "Rolf Rabenseifner" <[email protected]>, "MPI-WG Fortran working group" <[email protected]>, > "Anthony Skjellum" <[email protected]>, "Reinhold Bader" <[email protected]>, "Atsushi Hori" > <[email protected]>, "fortran standards email list for J3" <[email protected]> > Sent: Friday, June 16, 2017 3:16:57 PM > Subject: Re: [mpiwg-p2p] [MPIWG Fortran] FP16 16-bit-floating-point > Hi, > > I don't know the status of C standardization nor contact person > but the suggestion of 'short float' was seem to made in a WG. > > http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2016/p0192r0.pdf > http://www.open-std.org/jtc1/sc22/wg14/www/docs/n2016.pdf > > Regards, > Takahiro Kawashima, > Fujitsu ----- Original Message ----- > From: "longb" <[email protected]> > To: "MPI-WG Fortran working group" <[email protected]> > Cc: "Atsushi Hori" <[email protected]>, "Reinhold Bader" <[email protected]>, "fortran standards email list > for J3" <[email protected]> > Sent: Friday, June 16, 2017 7:22:42 PM > Subject: Re: [MPIWG Fortran] [mpiwg-p2p] FP16 16-bit-floating-point >> On Jun 16, 2017, at 7:19 PM, Rolf Rabenseifner <[email protected]> wrote: >> >> Jeff is partially right: >> If the Fortran user uses selected_real_kind(p, r), then all is done. >> >> On the other hand, >> I expect that the Fortran standardization body will do the same >> as the C standardization body, namely to add a new language Basic type. > > No. The basic type is REAL. This is just another KIND of REAL. This is not > much of an issue for the standard. It is a HUGE deal for implementations. > > Cheers, > Bill > > >> >> For this of course, we have to provide the corresponding MPI predefined >> datatype. >> Rolf >> >> >> ----- Original Message ----- >>> From: "Jeff Hammond" <[email protected]> >>> To: "MPI WG Point To Point Communications working group" >>> <[email protected]> >>> Cc: "Atsushi Hori" <[email protected]>, "Reinhold Bader" >>> <[email protected]>, "fortran standards email list >>> for J3" <[email protected]>, "MPI-WG Fortran working group" >>> <[email protected]> >>> Sent: Friday, June 16, 2017 5:11:24 PM >>> Subject: Re: [MPIWG Fortran] [mpiwg-p2p] FP16 16-bit-floating-point >> >>> No change to the MPI standard is required here. MPI_Type_create_f90_real is >>> already sufficient. >>> >>> "This function returns a predefined MPI datatype that matches a REAL variable of >>> KIND selected_real_kind(p, r)." - I do not see why we need to enumerate a >>> predefined datatype name associated with float16 in Fortran for this statement >>> to be true. An implementation can return a datatype with the appropriate >>> properties without being enumerated like MPI_REAL. >>> >>> "It is erroneous to supply values for p and r not supported by the compiler." - >>> Conversely, the user should be allowed to supply values that are supported by >>> the compiler (although the standard doesn't guarentee it today). MPI >>> implementations might not support every type the compiler does, as is already >>> the case for Fortran float128 (because MPI libraries are written in C, and do >>> not call back into Fortran to do math on these types, which may not be >>> identical to C extensions like __float128), but I consider that an >>> implementation defect. >>> >>> Thus, I propose to merely add the text that allows users to rely on >>> MPI_Type_create_f90_real for float16 in Fortran, provided that the compiler >>> supports it. It will then be up to implementations to figure out how to do math >>> on these types internally. >>> >>> While we are on this subject, we should be considering the more general >>> inadequacy of the current state of the MPI type system from the perspective of >>> reductions. See [ https://github.com/mpi-forum/mpi-issues/issues/18 | >>> https://github.com/mpi-forum/mpi-issues/issues/18 ] for details. >>> >>> As for ISO C/C++, I can talk to Clark Nelson if a better candidate is not >>> identified, but Lawrence Crowl is leading the C++ effort and I suspect the C >>> folks will follow, although I will confirm this with Clark. >>> >>> Jeff >>> >>> On Fri, Jun 16, 2017 at 6:16 AM, Kawashima, Takahiro < [ >>> mailto:[email protected] | [email protected] ] > wrote: >>> >>> >>> Hi, >>> >>> I don't know the status of C standardization nor contact person >>> but the suggestion of 'short float' was seem to made in a WG. >>> >>> [ http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2016/p0192r0.pdf | >>> http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2016/p0192r0.pdf ] >>> [ http://www.open-std.org/jtc1/sc22/wg14/www/docs/n2016.pdf | >>> http://www.open-std.org/jtc1/sc22/wg14/www/docs/n2016.pdf ] >>> >>> Regards, >>> Takahiro Kawashima, >>> Fujitsu >>> >>>> Tony, >>>> >>>> we try to find the type names used in C and Fortran before we define >>>> the new predefined MPI datatype handles for representing those >>>> language types. >>>> >>>> Who knows, whom we can contact on the C standardization side? >>>> >>>> Best regards >>>> Rolf >>>> >>>> ----- Original Message ----- >>>>> From: "Anthony Skjellum" < [ mailto:[email protected] | >>>>> [email protected] ] > >>>>> To: "MPI WG Point To Point Communications working group" < [ >>>>> mailto:[email protected] | [email protected] ] > >>>>> Cc: "Reinhold Bader" < [ mailto:[email protected] | >>>>> [email protected] ] >, "Atsushi Hori" < [ mailto:[email protected] | >>>>> [email protected] ] >, "fortran standards email list >>>>> for J3" < [ mailto:[email protected] | [email protected] ] >, "MPI-WG Fortran >>>>> working group" < [ mailto:[email protected] | >>>>> [email protected] ] > >>>>> Sent: Friday, June 16, 2017 2:50:00 PM >>>>> Subject: Re: [MPIWG Fortran] [mpiwg-p2p] FP16 16-bit-floating-point >>>> >>>>> Rolf, apart from the Fortan angle, may I strongly encourage that we adopt this >>>>> datatype for MPI-4. It is part of real MPI codes already, but now we have to >>>>> fake transfer datatypes as 16-bit integers or bytes... which means not really >>>>> right if heterogeneous interoperability were to be maintained. And this is a >>>>> canonical IEEE type now, as you note. There is also the "2 half-float" datatype >>>>> (32-bits) at least in CUDA to be looked at; maybe ignored or maybe supported, >>>>> but it is there too. Key to this MPI users and applications use half floats and >>>>> 2 half-floats :-) in practice. >>>>> >>>>> May I also suggest a forward look at the types in AVX-512, in case any of these >>>>> become particularly relevant in future. >>>>> At least 8-bit integers are conceptually new, apart from BYTE. [ >>>>> [ https://en.wikipedia.org/wiki/AVX-512 | https://en.wikipedia.org/wiki/AVX-512 >>>>> ] | [ https://en.wikipedia.org/wiki/AVX-512 | >>>>> https://en.wikipedia.org/wiki/AVX-512 ] ] >>>>> >>>>> Regards, >>>>> Tony >>>>> >>>>> >>>>> On Fri, Jun 16, 2017 at 6:52 AM, Rolf Rabenseifner < [ >>>>> mailto: [ mailto:[email protected] | [email protected] ] | [ >>>>> mailto:[email protected] | [email protected] ] ] > wrote: >>>>> >>>>> >>>>> Hi all together, >>>>> >>>>> I'm sitting in the MPI Forum Meeting and we discuss the new IEEE FP16 >>>>> datatype. >>>>> >>>>> Questions to the Fortran atandardization body: >>>>> >>>>> - Does the Fortran Standardization Body has already a proposal for >>>>> the new name in Fortran for this IEEE FP16? >>>>> >>>>> - Will be REAL*2 identical to IEEE FP16? >>>>> >>>>> Best regards >>>>> Rolf >>> _______________________________________________ >>> mpiwg-p2p mailing list >>> [ mailto:[email protected] | [email protected] ] >>> [ https://lists.mpi-forum.org/mailman/listinfo/mpiwg-p2p | >>> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-p2p ] >>> >>> >>> >>> -- >>> Jeff Hammond >>> [ mailto:[email protected] | [email protected] ] >>> [ http://jeffhammond.github.io/ | http://jeffhammond.github.io/ ] >>> >>> _______________________________________________ >>> mpiwg-fortran mailing list >>> [email protected] >>> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-fortran >> >> -- >> Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] . >> High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . >> University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . >> Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner . >> Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . >> _______________________________________________ >> mpiwg-fortran mailing list >> [email protected] >> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-fortran > > Bill Long > [email protected] > Principal Engineer, Fortran Technical Support & voice: 651-605-9024 > Bioinformatics Software Development fax: 651-605-9143 > Cray Inc./ 2131 Lindau Lane/ Suite 1000/ Bloomington, MN 55425 > > > _______________________________________________ > mpiwg-fortran mailing list > [email protected] > https://lists.mpi-forum.org/mailman/listinfo/mpiwg-fortran -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) .
3328
Age (days ago)
3328
Last active (days ago)
0 comments
1 participants
participants (1)
Rolf Rabenseifner
