[Mpi3-tools] Updates to DLL Discovery API proposal
2 Mar
2 Mar
'09
3:25 p.m.
Per the call today, I updated https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/MPI3Tools/dllapi to remove all references to MPIR_debug_gate, and changed the text to reflect that the debugger may read the value at any time. If the symbol does not exist, then the MPI doesn't support the DLL and the debugger shouldn't bother checking again. If the symbol exists and has a NULL value, the debugger should try again later. If the symbol exists and does not have a NULL value, then the debugger can try the DLLs listed in the array. I will likely not update the MPI handle debugging API proposal until after we get some feedback from the Forum. -- Jeff Squyres Cisco Systems
6357
Age (days ago)
6357
Last active (days ago)
0 comments
1 participants
participants (1)
Jeff Squyres
