Copy velocity slice from one boundary to another
Hi, Neks! I have two pipes in my simulation. They are placed near each other on one axis with empty space between. One of them with periodic boundary conditions on z direction, another one - inflow -> outflow. How can I copy velocity slice from one of boundary on first pipe with periodic bc to the inflow boundary on second pipe? Regards, Vatslav.
Vatslav, you will have to use the neknek script that allows you to exchange data between two Nek5000 sessions that are run simultaneously. You should have a look at the neknek examples to understand how to set up your usr file. Some of the subroutines that will be useful to you are located in the following link: http://www.mcs.anl.gov/research/projects/nek5/docs/html/multimesh_8f_source.... You will have to modify some of them to fit your needs since for example the subroutine ‘set_inflag’ is written to look for ‘in’ boundary conditions and replace them with ‘v ’. You will need a subroutine that looks for ‘in’ and substitute it with either ‘v ‘ or ‘P ‘ depending on the which pipe you are at. Marco On Mar 24, 2017, at 4:16 AM, [email protected]<mailto:[email protected]> wrote: Hi, Neks! I have two pipes in my simulation. They are placed near each other on one axis with empty space between. One of them with periodic boundary conditions on z direction, another one - inflow -> outflow. How can I copy velocity slice from one of boundary on first pipe with periodic bc to the inflow boundary on second pipe? Regards, Vatslav. _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
participants (1)
nek5000-users@lists.mcs.anl.gov
