Hello Nek's, I have a few questions on how to use the history points. I have seen on the wiki the following stuff:
History points
Specify grid points to monitor the specified variables in time. Example:
***** HISTORY AND INTEGRAL DATA ***** 1 POINTS. Var, Hcode, I, J, K, IEL UV P H 2 2 1 4
NOTE:
* Make sure LHIS in SIZEu is large enough
I bet Var stands for variable, but what do Hcode, I, J, K, and IEL stand for ? Once you have specified the location of your history point, let's say a point on the centerline of a stenotic flow at whatever streamwise station, how do you get the data concerning this history point? Do you have to change anything else in the output specification section ? I have tried to add the wiki lines up there directly in my blah.rea but once I ran the code I did not get any new files other than the expected blah.fld's. Regards, Jean-Christophe
participants (1)
nek5000-users@lists.mcs.anl.gov
