About the iobj in the drag calculation
Hi,all: I read Paul's reply in this mail https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2014-May/002756.html And got to know something about objects. As you say, the object is a collection of faces, here , I have a question about the iboj, how could I know which face it represent with iboj? As in turbChannel.usr, dragx_avg = alpha*dragx_avg + beta*0.5*(dragx(1)+dragx(2)) I think it means to do the time-average of the average dragx on planey1 and planey2, as 0.5*(dragx(1)+dragx(2)) indicates, while how to calculate the dragx on the planex1, planex2, planez1 and planez2? for the maxobj in this example is only 4 and dragx is defined as dragx(0:maxobj) Thank you Xianbei
Hi, I'm sorry to trouble. I find these lines in set_obj subroutine if (f.eq.1) iobj=1 ! lower wall if (f.eq.3) iobj=2 ! upper wall so this defines which wall to be represented. Another question comes that why the urms is calculate like do i=1,m write(56,3) yy(i)+1 & ,(yy(i)+1)*Re_tau & , (urms_pl(i)-(uavg_pl(i))**2)/u_tau**2 & , vrms_pl(i)/u_tau**2 & , wrms_pl(i)/u_tau**2 & , uvms_pl(i)/u_tau**2 write(57,3) yy(i) + 1. & , (yy(i)+1.)*Re_tau & , uavg_pl(i)/u_tau 3 format(1p15e17.9) enddo As can be seen,R_uu=(urms_pl(i)-(uavg_pl(i))**2)/u_tau**2, while R_vv=vrms_pl(i)/u_tau**2,why? 在 2014-05-29 02:24:34,[email protected] 写道: Hi,all: I read Paul's reply in this mail https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2014-May/002756.html And got to know something about objects. As you say, the object is a collection of faces, here , I have a question about the iboj, how could I know which face it represent with iboj? As in turbChannel.usr, dragx_avg = alpha*dragx_avg + beta*0.5*(dragx(1)+dragx(2)) I think it means to do the time-average of the average dragx on planey1 and planey2, as 0.5*(dragx(1)+dragx(2)) indicates, while how to calculate the dragx on the planex1, planex2, planez1 and planez2? for the maxobj in this example is only 4 and dragx is defined as dragx(0:maxobj) Thank you Xianbei 来自网易手机号码邮箱了解更多
These are just rescalings of turbulent fluctuations in terms of wall units, which allows them to be compared with other data in the literature. On Thu, 29 May 2014, [email protected] wrote:
As can be seen,R_uu=(urms_pl(i)-(uavg_pl(i))**2)/u_tau**2, while R_vv=vrms_pl(i)/u_tau**2,why? �� 2014-05-29 02:24:34��[email protected] д���� Hi,all: I read Paul's reply in this mail https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2014-May/002756.html And got to know something about objects. As you say, the object is a collection of faces, here , I have a question about the iboj, how could I know which face it represent with iboj? As in turbChannel.usr, dragx_avg = alpha*dragx_avg + beta*0.5*(dragx(1)+dragx(2)) I think it means to do the time-average of the average dragx on planey1 and planey2, as 0.5*(dragx(1)+dragx(2)) indicates, while how to calculate the dragx on the planex1, planex2, planez1 and planez2? for the maxobj in this example is only 4 and dragx is defined as dragx(0:maxobj) Thank you Xianbei ���������ֻ����������˽����
Thank you, I know the urms/u_tau**2 is to rescale the data, but why (urms_pl(i)-(uavg_pl(i))**2) but the other components are not? I mean minus the uavg_pl(i). At 2014-05-29 06:56:56, [email protected] wrote:
Thank you Xianbei
来自网易手机号码邮箱了解更多
Hi Xianbei, You can define more objects by picking your own surface discriminators (which will be dependent on your particular application). If you need more than 4 objects, you can increase maxobj in SIZE. Typically, dragx(0) would be the sum of the drag on all the objects --- this is sometimes useful. If you have (say) a 4-sided channel, you can just define one object instead of 4, and set it to be the collection of all faces for which cbc(f,e,1)='W '. Paul On Thu, 29 May 2014, [email protected] wrote:
Thank you Xianbei
Thank you very much,Paul. Now I get stuck in the Energy spectrum and two-point correlation, I'll go through the code first, if a problem occurs, I'll show it. Xianbei At 2014-05-29 06:54:10, [email protected] wrote:
Hi Xianbei,
Paul
Thank you Xianbei _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Hi,Paul: I'm confused about part of the subroutine userchk in turbChannel.usr if(icalld.eq.0) then call rzero(uavg,n) call rzero(urms,n) call rzero(vrms,n) call rzero(wrms,n) call rzero(uvms,n) atime = 0. timel = time call planar_average_s(yy ,ym1 ,w1,w2) icalld = 1 endif dtime = time - timel atime = atime + dtime if (atime.ne.0. .and. dtime.ne.0.) then beta = dtime/atime alpha = 1.-beta ifverbose = .false. call avg1(uavg,vx ,alpha,beta,n,'uavg',ifverbose) call avg2(urms,vx ,alpha,beta,n,'urms',ifverbose) call avg2(vrms,vy ,alpha,beta,n,'vrms',ifverbose) call avg2(wrms,vz ,alpha,beta,n,'wrms',ifverbose) call avg3(uvms,vx,vy,alpha,beta,n,'uvmm',ifverbose) dragx_avg = alpha*dragx_avg + beta*0.5*(dragx(1)+dragx(2)) ! averaging over statistical homogeneous directions (r-t) call planar_average_s(uavg_pl,uavg,w1,w2) call planar_average_s(urms_pl,urms,w1,w2) call planar_average_s(vrms_pl,vrms,w1,w2) call planar_average_s(wrms_pl,wrms,w1,w2) call planar_average_s(uvms_pl,uvms,w1,w2) ! average over half the channel height m = ny1*nely do i=1,ny1*nely/2 uavg_pl(i) = 0.5 * (uavg_pl(i) + uavg_pl(m-i+1)) urms_pl(i) = 0.5 * (urms_pl(i) + urms_pl(m-i+1)) vrms_pl(i) = 0.5 * (vrms_pl(i) + vrms_pl(m-i+1)) wrms_pl(i) = 0.5 * (wrms_pl(i) + wrms_pl(m-i+1)) enddo endif tw = dragx_avg/A_w + 1.e-50 u_tau = sqrt(tw/rho) Re_tau = u_tau*delta/dnu diff = (tw-ffx_new)/tw if(nid.eq.0) write(6,1) istep,time,e2,ffx_new,diff 1 format(i6,1p4e17.9,' err2') ! write statistics to file iostep_avg = param(68) if(nid.eq.0 .and. istep.gt.0 .and. & mod(istep,iostep_avg).eq.0) then write(6,*) 'Dumping statistics ...' open(unit=56,file='reystresses.dat') write(56,'(A,1pe14.7)') '#time = ', time write(56,'(A)') & '# y y+ R_uu R_vv R_ww R_uv' open(unit=57,file='means.dat') write(57,'(A,1pe14.7)') '#time = ', time write(57,'(A)') & '# y y+ Umean' m = ny1*nely/2 do i=1,m write(56,3) yy(i)+1 & ,(yy(i)+1)*Re_tau & , (urms_pl(i)-(uavg_pl(i))**2)/u_tau**2 & , vrms_pl(i)/u_tau**2 & , wrms_pl(i)/u_tau**2 & , uvms_pl(i)/u_tau**2 write(57,3) yy(i) + 1. & , (yy(i)+1.)*Re_tau & , uavg_pl(i)/u_tau 3 format(1p15e17.9) enddo close(56) close(57) endif return end I look into the code of navier5.f and find that avg1, avg2 returns the time average of vx and vx**2 in this example, so if we want to calculate the Reynolds stress, the formulation should be : R_uu=urms-uavg**2 also, if normalized, R_uu=(urms-uavg**2)/u_tau**2 so are the other components I think this is the right way instead of that in the example At 2014-05-29 06:54:10, [email protected] wrote:
Hi Xianbei,
Paul
Hi Xianbi, You are right in defining the Reynolds Stresses. However, if you look carefully, this is an example of fully developed turbulent Channel. Hence the statistics is independant of the x direction (streamwise). Also, the statistics is taken independant of z direction (no wall in z). x and z both have periodic BC. Hence before calculating R_uu, R_vv etc, we just do the spatial planar averaging in the xz plane. Since for homogeneous flow, that should equal an ensemble average. You can modify the turbChannel to a non-homogeneous flow, in which case you can define Reynolds stresses just like you said, and they would spatially varying. Thanks, Tanmoy On Thu, May 29, 2014 at 5:22 AM, <[email protected]> wrote:
m = ny1*nely/2
return end
Hi Xianbei,
Paul
来自网易手机号码邮箱了解更多 <http://shouji.163.com>
Hi,Tanmoy: Thank you for your reply. Yes, the x and z are the homogenous directions, so vy_avg and vz_avg should be 0 in this way. I have another question on the output. I want to output the instaneous velocity field in the x y z vx vy vz format, so that I can do the energy spectrum and two-point correlation in the Matlab(in Nek5000, it's not so convenient to output Ek and two-point correlation directly, in my opinion). So I search the mailist and find a subroutine named 'sem2lex' which can convert us(ix,iy,iz,le) to ul(ix,ie,iy,je,iz,ke), my question is: how can I output this with a different timestep interval?I need more sample point of the instaneous velocity than the means. Xianbei At 2014-05-30 01:00:15, [email protected] wrote: Hi Xianbi, You are right in defining the Reynolds Stresses. However, if you look carefully, this is an example of fully developed turbulent Channel. Hence the statistics is independant of the x direction (streamwise). Also, the statistics is taken independant of z direction (no wall in z). x and z both have periodic BC. Hence before calculating R_uu, R_vv etc, we just do the spatial planar averaging in the xz plane. Since for homogeneous flow, that should equal an ensemble average. You can modify the turbChannel to a non-homogeneous flow, in which case you can define Reynolds stresses just like you said, and they would spatially varying. Thanks, Tanmoy On Thu, May 29, 2014 at 5:22 AM, <[email protected]> wrote: Hi,Paul: I'm confused about part of the subroutine userchk in turbChannel.usr if(icalld.eq.0) then call rzero(uavg,n) call rzero(urms,n) call rzero(vrms,n) call rzero(wrms,n) call rzero(uvms,n) atime = 0. timel = time call planar_average_s(yy ,ym1 ,w1,w2) icalld = 1 endif dtime = time - timel atime = atime + dtime if (atime.ne.0. .and. dtime.ne.0.) then beta = dtime/atime alpha = 1.-beta ifverbose = .false. call avg1(uavg,vx ,alpha,beta,n,'uavg',ifverbose) call avg2(urms,vx ,alpha,beta,n,'urms',ifverbose) call avg2(vrms,vy ,alpha,beta,n,'vrms',ifverbose) call avg2(wrms,vz ,alpha,beta,n,'wrms',ifverbose) call avg3(uvms,vx,vy,alpha,beta,n,'uvmm',ifverbose) dragx_avg = alpha*dragx_avg + beta*0.5*(dragx(1)+dragx(2)) ! averaging over statistical homogeneous directions (r-t) call planar_average_s(uavg_pl,uavg,w1,w2) call planar_average_s(urms_pl,urms,w1,w2) call planar_average_s(vrms_pl,vrms,w1,w2) call planar_average_s(wrms_pl,wrms,w1,w2) call planar_average_s(uvms_pl,uvms,w1,w2) ! average over half the channel height m = ny1*nely do i=1,ny1*nely/2 uavg_pl(i) = 0.5 * (uavg_pl(i) + uavg_pl(m-i+1)) urms_pl(i) = 0.5 * (urms_pl(i) + urms_pl(m-i+1)) vrms_pl(i) = 0.5 * (vrms_pl(i) + vrms_pl(m-i+1)) wrms_pl(i) = 0.5 * (wrms_pl(i) + wrms_pl(m-i+1)) enddo endif tw = dragx_avg/A_w + 1.e-50 u_tau = sqrt(tw/rho) Re_tau = u_tau*delta/dnu diff = (tw-ffx_new)/tw if(nid.eq.0) write(6,1) istep,time,e2,ffx_new,diff 1 format(i6,1p4e17.9,' err2') ! write statistics to file iostep_avg = param(68) if(nid.eq.0 .and. istep.gt.0 .and. & mod(istep,iostep_avg).eq.0) then write(6,*) 'Dumping statistics ...' open(unit=56,file='reystresses.dat') write(56,'(A,1pe14.7)') '#time = ', time write(56,'(A)') & '# y y+ R_uu R_vv R_ww R_uv' open(unit=57,file='means.dat') write(57,'(A,1pe14.7)') '#time = ', time write(57,'(A)') & '# y y+ Umean' m = ny1*nely/2 do i=1,m write(56,3) yy(i)+1 & ,(yy(i)+1)*Re_tau & , (urms_pl(i)-(uavg_pl(i))**2)/u_tau**2 & , vrms_pl(i)/u_tau**2 & , wrms_pl(i)/u_tau**2 & , uvms_pl(i)/u_tau**2 write(57,3) yy(i) + 1. & , (yy(i)+1.)*Re_tau & , uavg_pl(i)/u_tau 3 format(1p15e17.9) enddo close(56) close(57) endif return end I look into the code of navier5.f and find that avg1, avg2 returns the time average of vx and vx**2 in this example, so if we want to calculate the Reynolds stress, the formulation should be : R_uu=urms-uavg**2 also, if normalized, R_uu=(urms-uavg**2)/u_tau**2 so are the other components I think this is the right way instead of that in the example At 2014-05-29 06:54:10, [email protected] wrote:
Hi Xianbei,
Paul
来自网易手机号码邮箱了解更多 _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
participants (1)
nek5000-users@lists.mcs.anl.gov
