Conjugate heat transfer with complex properties
Hello, I have a conjugate heat transfer problem where the solid material is a composite that undergoes a phase transformation. Is it possible to model a material like this in Nek5000? Thanks, Adam Lange
Hi Adam, Can you be more specific? Is it melting? In principle, it should be possible as that was one of the original applications for Nek5000. In practice, however, I would rate that as still a research area (at least from the Nek perspective). I guess that melting is much easier than freezing, however. Paul ________________________________ From: Nek5000-users <[email protected]> on behalf of [email protected] <[email protected]> Sent: Thursday, August 3, 2017 8:29:09 AM To: [email protected] Subject: [Nek5000-users] Conjugate heat transfer with complex properties Hello, I have a conjugate heat transfer problem where the solid material is a composite that undergoes a phase transformation. Is it possible to model a material like this in Nek5000? Thanks, Adam Lange _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Hi Paul, Yep, there's some melting going on. There's a porous structure that does not melt and wax trapped in the porous structure. The wax melts and re-solidifies. There really nothing complex happening with the geometry. A static mesh should do the job. The material properties are the challenge. I think I could model the material behavior as having a non-linear specific heat capacity as a function of temperature. Adam On 08/03/2017 09:30 AM, [email protected] wrote:
Hi Adam,
Paul
------------------------------------------------------------------------ *From:* Nek5000-users <[email protected]> on behalf of [email protected] <[email protected]> *Sent:* Thursday, August 3, 2017 8:29:09 AM *To:* [email protected] *Subject:* [Nek5000-users] Conjugate heat transfer with complex properties Hello,
Adam Lange
Yes - that should work. Set ifuservp = .true. and then, in uservp() if (ifield.eq.1) then ! fluid properties udiff = param(2) utrans = param(1) else ! thermal properties udiff = your diffusivity utrans = your rhoCp endif ________________________________ From: Nek5000-users <[email protected]> on behalf of [email protected] <[email protected]> Sent: Thursday, August 3, 2017 10:13:03 AM To: [email protected] Subject: Re: [Nek5000-users] Conjugate heat transfer with complex properties Hi Paul, Yep, there's some melting going on. There's a porous structure that does not melt and wax trapped in the porous structure. The wax melts and re-solidifies. There really nothing complex happening with the geometry. A static mesh should do the job. The material properties are the challenge. I think I could model the material behavior as having a non-linear specific heat capacity as a function of temperature. Adam On 08/03/2017 09:30 AM, [email protected]<mailto:[email protected]> wrote: Hi Adam, Can you be more specific? Is it melting? In principle, it should be possible as that was one of the original applications for Nek5000. In practice, however, I would rate that as still a research area (at least from the Nek perspective). I guess that melting is much easier than freezing, however. Paul ________________________________ From: Nek5000-users <[email protected]><mailto:[email protected]> on behalf of [email protected]<mailto:[email protected]> <[email protected]><mailto:[email protected]> Sent: Thursday, August 3, 2017 8:29:09 AM To: [email protected]<mailto:[email protected]> Subject: [Nek5000-users] Conjugate heat transfer with complex properties Hello, I have a conjugate heat transfer problem where the solid material is a composite that undergoes a phase transformation. Is it possible to model a material like this in Nek5000? Thanks, Adam Lange _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Awesome, thank you Paul. Adam On 08/03/2017 11:19 AM, [email protected] wrote:
udiff = param(2)
utrans = param(1)
utrans = your rhoCp
endif
------------------------------------------------------------------------ *From:* Nek5000-users <[email protected]> on behalf of [email protected] <[email protected]> *Sent:* Thursday, August 3, 2017 10:13:03 AM *To:* [email protected] *Subject:* Re: [Nek5000-users] Conjugate heat transfer with complex properties
Hi Paul,
Adam
Hi Adam,
Paul
Adam Lange
participants (1)
nek5000-users@lists.mcs.anl.gov
