Hi all, I want to add perturbation of specific order (e.g. 10^-08) to the whole velocity field at each time-step. The velocity and pressure are both considered on GLL points. After adding perturbation, to have velocity as continuous function across the elements dsavg() is called (I found the info in one of the threads). I think it changes the order of perturbation near to the element boundary. I was wondering if there is other way to do so. This is my first mail to the group and I am using the code for my thesis. Thanks in advance! Best regards, Sayed MSc. COSSE KTH, Sweden FAU-Erlangen,Germany
Hi Sayed, When you say it changed the order, how do you mean? It should indeed just averaged the interface values, so it should be of the same order as the initial perturbation. Paul On Tue, 14 May 2013, [email protected] wrote:
Hi all,
Thanks in advance!
_______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Hi Paul, Sorry, I should have written it in more details. I have the base flow u_{base} calculated, already continuous across the elements. Now, I am trying to add perturbation doing to the base flow: u = u_{base}+\epsilon*u_{perturb} at each time-step. \epsilon being the order (e,g 10^-08) and u_{perturb} varies from 0 to 1 on each grid points. Best Sayed
Hi Sayed,
Paul
Hi all,
Thanks in advance!
To add more, I found that near to the element boundary if I do the averaging(dsavg()) the order cannot be maintained at those grid points. Sayed
Hi Paul,
Best Sayed
Hi Sayed,
Paul
Hi all,
Thanks in advance!
Hi Sayed, Can you send me the .usr file, off-line? Best, Paul ----- Original Message ----- From: [email protected] To: [email protected] Sent: Wednesday, May 15, 2013 6:29:10 PM Subject: Re: [Nek5000-users] Maintaining order of perturbation To add more, I found that near to the element boundary if I do the averaging(dsavg()) the order cannot be maintained at those grid points. Sayed
Hi Paul,
Best Sayed
Hi Sayed,
Paul
Hi all,
Thanks in advance!
participants (1)
nek5000-users@lists.mcs.anl.gov
