Hi Neks, We have been running the perturbation mode in order to study the linear evolution of disturbances in a couple of 2D boundary layer cases and are now setting up a 3D boundary layer case. Already for the 2D cases we experienced that the timestep needs to be decreased significantly compared to a corresponding nonlinear simulation in order to yield a numerically stable simulation. For the nonlinear simulations we put the disturbance with a small amplitude on top of the baseflow. Hence, running the perturbation mode for the 2D cases was more expensive than running a nonlinear simulation but still reasonable. However, the 3D case seems to become much more expensive. We first ran a nonlinear simulation as described above and compared the disturbance evolution to results of the parabolised stability equations which matched perfectly. Running then the perturbation mode for the same disturbance with the same base flow did not yield a stable simulation even when the timestep was reduced (divided by 5). The disturbance amplitude exploded very early. We then took a higher box and increased the resolution which made things a little better meaning that the simulation exploded much later. However, it is still not stable although the resolution is higher and the timestep is much smaller compared to the corresponding nonlinear simulation which worked fine. Also, the number of pressure iterations is around 20-30 times higher. Is there any reason why the linear stability equations in nekton should behave so much different than the full Navier-Stokes? Are there some parameters (filtering etc.) that have to be used differently in this case? Best regards, David -- David Tempelmann Linn� Flow Center, Mechanics KTH SE-100 44, Stockholm, Sweden Phone: +46 8 7907161 E-mail: [email protected]
Hi David, The perturbation solver was developed roughly 10 years back and hasn't been extensively exercised in recent years. As it is updated only when used (as you guys are doing now) there may be some maintenance that is overdue. There is no intrinsic reason why the perturbation solver should need a smaller timestep than the nonlinear one, so it sounds as though something is amiss; and most likely this is something that is fairly readily remedied. Some questions: .Are you using IFCHAR = true for your nonlinear solver? (I'm not certain of the status of IFCHAR + IFPERT at the moment.) Given that I'll be there next week we can look at this first-hand. I understand that you guys have already encountered (and perhaps resolved?) some issues with the perturbation solver, so hopefully we can get it all straightened out. If you'd like to send me the case files, I can take a quick look now. (You can email me off-list...) I look forward to meeting you next week! Best regards, Paul On Mon, 3 Jan 2011, [email protected] wrote:
Hi Neks,
Best regards,
David
_______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
On this topic, here are a couple of observations: 1. Perturbation solver was running slower than the nonlinear (std) solver because the perturbation solver did not use projection [Fischer1998] to accelerate the pressure solver. I've modified this so that pressure projection will be used for the perturbation solver if the following conditions are met: a. # perturbation modes = 1 b. baseflow is _not_ computed. These conditions could likely be relaxed, but for robustness I put them in since I don't have time to test all possible combinations at the moment. The rationale for these restrictions is that we (may or) may not want to mix the approximation spaces from the different pressure solves that are used to generate the initial guesses for each pressure solve. The above conditions ensure that pressure projection is used when there is only a single unknown pressure field and thus there will not be cross- population of the approximation space. [ Most likely, it would not hurt to have multiple source for the approximation space, but things get tricky when there are linear dependencies and my discriminators to identify these conditions are not robust.] 2. Linear solver was blowing up while nonlinear was not. The case in question is high Reynolds number (minimally dissipative) with TORDER=3 --- this case is in fact not guaranteed to be stable because the BDF3 timestepper is not A-stable, i.e., there are certain regions in the on the imaginary axis that are unstable. For some reason, this issue is cured for the nonlinear case with filtering [FischerMullen2001]. It appears, however, that the same fix does not cure these linear problems -- not certain why. The fix in this case seems to be to switch to TORDER=2, which has standard (i.e., CFL type) stability constraints and behavior. -- Please let me know if you have any further issues with this, and thanks to the KTH guys for providing a test case! Paul On Mon, 3 Jan 2011, [email protected] wrote:
Hi Neks,
Best regards,
David
participants (1)
nek5000-users@lists.mcs.anl.gov
