All elements deformed :: regenerate geometry data
Hi, I have prepared a 3D mesh in GAMBIT and used the matlab converter to make the .rea and .map file. When I use these files for computation, things appear to go on nicely and the flow field that I get is not different from what I expect. However, I notice the following lines in the output file which says that the geometry has been regenerated. What does this mean? Would it comprise the quality of the mesh near the wall? Reading checkpoint data byte swap: F 6.543210 -2.9312772E+35 FILE: restart.f00001 0 2.7300E+02 done :: Read checkpoint data avg data-throughput = 137.8MBps io-nodes = 1736 xyz min -3.5000 0.0000 -10.000 uvwpt min -1.5151 -1.7105 -1.6631 -0.87366 0.0000 PS min 0.0000 0.99000E+22 xyz max 60.000 3.1200 10.000 uvwpt max 2.2376 0.91592 1.7789 0.47959 0.0000 PS max 0.0000 -0.99000E+22 Restart: recompute geom. factors. regenerate geometry data 1 NOTE: All elements deformed , param(59) ^=0 done :: regenerate geometry data 1 done :: set initial conditions call userchk Many thanks, NN.
participants (1)
nek5000-users@lists.mcs.anl.gov
