Re: [Nek5000-users] Interpolation between two meshes
We have tested glfdr() using different cases/machines and it worked fine. With the information below I cannot say what's going wrong. - Is your source fld in double precision? - Do have any additional information where it hangs or crashes? - Can you please test gfldr() say with turbChannel (NekExamples). Stefan -----Original message-----
From:[email protected] <[email protected]> Sent: Tuesday 28th March 2017 22:46 To: [email protected] Subject: Re: [Nek5000-users] Interpolation between two meshes
Hi Stefan,
In case the attachments didn't go through, please see below for the .usr file and log file. I only used 'userchk' and 'usrdat' in the .usr file for interpolation. The other subroutines are empty. (I added several print lines in 'gfldr.f' to see where the interpolation halted.)
Best regards, Tony
.USR FILE: c----------------------------------------------------------------------- subroutine userchk() include 'SIZE' include 'TOTAL' include 'ZPER' include 'CTIMER' include 'RESTART'
character*132 sourcefld
sourcefld='source.f00001' call gfldr(sourcefld) call outpost(vx,vy,vz,pr,t,'rst') call exitt()
return end c----------------------------------------------------------------------- subroutine usrdat() ! This routine to modify element vertices include 'SIZE' include 'TOTAL'
parameter (ielx=150) parameter (iely=22) parameter (ielz=142) integer i,e,eg,ex,ey,ez real cony
cony = 2.36d0
do e=1,nelv eg = lglel(e) if(eg<=ielx*iely*ielz) then call get_exyz(ex,ey,ez,eg,ielx,iely,ielz)
do i=1,8 if(i<=2 .or. i==5 .or. i==6) then if((yc(i,e)>0.0e0.and.yc(i,e)<1.0e0).OR. & (yc(i,e)>1.0e0.and.yc(i,e)<2.0e0)) then yc(i,e) = 2.0e0*Real(ey-1)/Real(iely) end if else if(i==3 .or. i==4 .or. i>=7) then if((yc(i,e)>0.0e0.and.yc(i,e)<1.0e0).OR. & (yc(i,e)>1.0e0.and.yc(i,e)<2.0e0)) then yc(i,e) = 2.0e0*Real(ey)/Real(iely) end if end if end do
end if end do
do e=1,nelv eg = lglel(e) if(eg==1) print*,yc(1,e),yc(2,e),yc(5,e),yc(6,e) if(eg==1) print*,yc(3,e),yc(4,e),yc(7,e),yc(8,e) do i=1,8 if(yc(i,e)>0.0e0 .AND. yc(i,e)<1.0e0) then yc(i,e) = yc(i,e)-1.0e0 yc(i,e) = tanh(cony*yc(i,e))/tanh(cony) yc(i,e) = yc(i,e)1.0e0 else if(yc(i,e)>1.0e0 .AND. yc(i,e)<2.0e0) then yc(i,e) = yc(i,e)-1.0e0 yc(i,e) = tanh(cony*yc(i,e))/tanh(cony) yc(i,e) = yc(i,e)1.0e0 end if end do end do
LOG FILE:
/----------------------------------------------------------\\ | _ __ ______ __ __ ______ ____ ____ ____ | | / | / // ____// //_/ / ____/ / __ \\/ __ \\/ __ \\ | | / |/ // __/ / ,< /___ \\ / / / // / / // / / / | | / /| // /___ / /| | ____/ / / /_/ // /_/ // /_/ / | | /_/ |_//_____//_/ |_|/_____/ \\___/ \\___/ \\___/ | | | |----------------------------------------------------------| | | | NEK5000: Open Source Spectral Element Solver | | COPYRIGHT (c) 2008-2017 UCHICAGO ARGONNE, LLC | | Version: 17.0.0 | | Web: http://nek5000.mcs.anl.gov | | | \\----------------------------------------------------------/
Number of processors: 720 REAL wdsize : 8 INTEGER wdsize : 4 Timer accuracy : 9.54E-08 Reading /work/e01/e01/tony/geometry_nonosci_cavity/interp.rea
mapping elements to processors Reading /work/e01/e01/tony/geometry_nonosci_cavity/interp.map element load imbalance: 1 652 653 done :: mapping elements to processors
0 objects found 118 Parameters from file: 1 1.00000 p001 DENSITY 2 -3150.00 p002 VISCOS 12 -0.11750E-01 p012 DT 15 500.000 p015 IOSTEP 21 0.100000E-07 p021 DIVERGENCE 22 0.100000E-07 p022 HELMHOLTZ 26 2.00000 p026 COURANT/NTAU 27 3.00000 p027 TORDER 59 0.00000 p059 !=0 --> full Jac. eval. for each el. 63 8.00000 p063 =8 --> force 8-byte output 65 1.00000 p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs 66 6.00000 p066 output : <0=ascii, else binary 67 6.00000 p067 restart: <0=ascii, else binary 93 20.0000 p093 Number of previous pressure solns saved 94 5.00000 p094 start projecting velocity after p94 step 95 5.00000 p095 start projecting pressure after p95 step 99 3.00000 p099 dealiasing: <0--> off/3--> old/4--> new 103 0.10000E-01 p103 weight of stabilizing filter (.01)
nelgt/nelgv/lelt: 469500 469500 653 lx1 /lx2 /lx3 : 8 8 8 done :: read .rea file 45.222 sec
setup mesh topology Right-handed check complete for 469500 elements. OK. setvert3d: 8 60855000 162267000 60855000 60855000 call usrsetvert done :: usrsetvert
gs_setup: 10325502 unique labels shared pairwise times (avg, min, max): 0.00044986 0.00033021 0.000500798 crystal router : 0.00145524 0.00143301 0.0014781 used all_to_all method: pairwise handle bytes (avg, min, max): 2.64212e06 2463020 2796252 buffer bytes (avg, min, max): 491593 352288 632640 setupds time 5.3504E-01 seconds 0 8 60855000 469500 8 max multiplicity done :: setup mesh topology
0.000000000000000E000 0.000000000000000E000 0.000000000000000E000 0.000000000000000E000 9.090909090909091E-002 9.090909090909091E-002 9.090909090909091E-002 9.090909090909091E-002 call usrdat done :: usrdat
generate geometry data NOTE: All elements deformed , param(59) ^=0 done :: generate geometry data
call usrdat2 done :: usrdat2
regenerate geometry data 1 NOTE: All elements deformed , param(59) ^=0 done :: regenerate geometry data 1
verify mesh topology 0.000000000000000E000 6.00000000000000 Xrange -0.120000000000000 2.00000000000000 Yrange 0.000000000000000E000 49.7000000000000 Zrange done :: verify mesh topology
IFTRAN = T IFFLOW = T IFHEAT = F IFSPLIT = T IFLOMACH = F IFUSERVP = F IFUSERMV = F IFSTRS = F IFCHAR = T IFCYCLIC = F IFAXIS = F IFMVBD = F IFMELT = F IFMODEL = F IFKEPS = F IFMOAB = F IFNEKNEK = F IFSYNC = T
IFVCOR = F IFINTQ = F IFCWUZ = F IFSWALL = F IFGEOM = F IFSURT = F IFWCNO = F
IFTMSH for field 1 = F IFADVC for field 1 = T IFNONL for field 1 = F
Dealiasing enabled, lxd= 12 verify mesh topology 0.000000000000000E000 6.00000000000000 Xrange -0.120000000000000 2.00000000000000 Yrange 0.000000000000000E000 49.7000000000000 Zrange done :: verify mesh topology
call usrdat3 done :: usrdat3
set initial conditions nekuic (1) for ifld 1 call nekuic for vel xyz min 0.0000 -0.12000 0.0000 uvwpt min 0.0000 0.0000 0.0000 0.0000 0.0000 xyz max 6.0000 2.0000 49.700 uvwpt max 0.0000 0.0000 0.0000 0.0000 0.0000 done :: set initial conditions
gridpoints unique/tot: 162267000 240384000 dofs: 159972750 162104250
Initialization successfully completed 46.588 sec
nsteps=0 -> skip time loop running solver in post processing mode
call userchk call gfldr byte swap: F 6.543210 -2.9312772E35 sourcefld X 0.000000000000000E000 6.00000000000000 sourcefld Y -0.120000000000000 2.00000000000000 sourcefld Z 0.000000000000000E000 49.7000000000000 CHECK interp prepare CHECK interp read
----------- From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]> Sent: 28 March 2017 20:51 To: [email protected] Subject: Nek5000-users Digest, Vol 97, Issue 33
Message: 3 Date: Tue, 28 Mar 2017 19:51:04 0000 From: [email protected] To: "[email protected]" <[email protected]> Subject: Re: [Nek5000-users] Interpolation between two meshes Message-ID: <[email protected]> Content-Type: text/plain; charset="iso-8859-1"
Hi Stefan,
Many thanks for your reply. I'm running my simulations on ARCHER (Cray XC30 supercomputer) and I'm using the Intel compiler.
The current simulation has 469500 elements with polynomial order of 7. The source field I used for interpolation has 383700 elements with the same polynomial order. The size of the source field is about 10GB. I'm not sure if it can be easily transferred. But I have attached my .usr and log files herewith (also the gfldr.f with few added checking lines). I ran the interpolation using 720 processors.
Please have a look and let me know if you need further information about the case. Thank you very much for you help.
Best regards,
Tony _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
participants (1)
nek5000-users@lists.mcs.anl.gov
