Good morning to all users, I've created a mesh on GAMBIT and then converted it to Nek using a Matlab software that I found in this community. The conversion seems to have worked fine, but right now I want to launch the simulation with several processors. Therefore, I need to run the "genmap" function and I am having trouble with it. Could anyone explain me how to create the .map file? I've tried writing the command "genmap" in the terminal with the corresponding directories but it's not working. The .rea/.usr/SIZE, etc files are in directory /home3/Desktop/R0025 While the genmap file is in the directory /home3/Programmi/nek5_svn/trunk/tools/genmap. What should I exactly write in the terminal as a command? Thank you very much, Roger
Roger, did you build genmap? If you did you should see a ‘bin’ directory under the nek5000 directory that contains executables like genmap, genbox, … All executable are build by running './maketools' all in the tools directory. Marco
Roger _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Thanks for the answer Marco, Unfortunately I am pretty new to the software so I didn't know these kind of basic things. The problem is solved now. Thanks. El dc., 27 de juny 2018, 15:05, <[email protected]> va escriure:
Roger,
Marco
participants (1)
nek5000-users@lists.mcs.anl.gov
