Hi nek, I want to generate a 2d pipe mesh using prenek and add 3 elements in first quadrant using [(0, 0), (0.0045, 0), (0.003536, 0.003536), (0, 0.0045)], [(0.0125, 0), (0.00884, 0.00884), (0.003536, 0.003536), (0.0045, 0)], and [(0, 0.0125), (0.00884, 0.00884), (0.003536, 0.003536), (0, 0.00045)] for 3 elements respectively. But I usually add the element of [(0, 0.0125), (0.00884, 0.00884), (0.003536, 0.003536), (0, 0.00045)] with some difference which would happened on the first point I select. Do you know how could I click the points very accurately? Kind regards, Jian
Hi Jian, You can click in the menu area instead of on the screen, and then type the values in. Or, you can use SET GRID to change the grid background such that it contains your point of interest (Sometimes this is more useful than the above if you have a lot of points.) Or, you can build a list of points of the form: npoints x1 y1 x2 y2 ... xnpoints ynpoints in a file called "obj.dat" and then click on DEFINE OBJECT, which will set these points to be the snap points in standard element-input mode. Then, use SET GRID to toggle between these points and the other standard background grid options. Paul ________________________________ From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]] Sent: Wednesday, April 19, 2017 8:58 AM To: [email protected] Subject: [Nek5000-users] prenek Hi nek, I want to generate a 2d pipe mesh using prenek and add 3 elements in first quadrant using [(0, 0), (0.0045, 0), (0.003536, 0.003536), (0, 0.0045)], [(0.0125, 0), (0.00884, 0.00884), (0.003536, 0.003536), (0.0045, 0)], and [(0, 0.0125), (0.00884, 0.00884), (0.003536, 0.003536), (0, 0.00045)] for 3 elements respectively. But I usually add the element of [(0, 0.0125), (0.00884, 0.00884), (0.003536, 0.003536), (0, 0.00045)] with some difference which would happened on the first point I select. Do you know how could I click the points very accurately? Kind regards, Jian
participants (1)
nek5000-users@lists.mcs.anl.gov
