How to give NEK5000 boundary conditions to exodus mesh file
Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you
I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [email protected]<mailto:[email protected]> wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Thank you . So here the 1,2,3,4 refers to the Side set numbers that we give as B.C in ICEM? Thank you very much Sijo De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Yes, you are correct. 1, 2, .. are the boundary indices in your exodus file. The ‘1’ in bc(5,j,i,1) refers to the velocity field. Marco On May 31, 2018, at 8:56 AM, [email protected]<mailto:[email protected]> wrote: Thank you . So here the 1,2,3,4 refers to the Side set numbers that we give as B.C in ICEM? Thank you very much Sijo ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [email protected]<mailto:[email protected]> wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Perfect. i will give a try Thanks Marco. De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 14:58:17 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Yes, you are correct. 1, 2, .. are the boundary indices in your exodus file. The ‘1’ in bc(5,j,i,1) refers to the velocity field. Marco On May 31, 2018, at 8:56 AM, [ mailto:[email protected] | [email protected] ] wrote: Thank you . So here the 1,2,3,4 refers to the Side set numbers that we give as B.C in ICEM? Thank you very much Sijo De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco BQ_BEGIN On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users BQ_END _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco On May 31, 2018, at 9:11 AM, [email protected]<mailto:[email protected]> wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [email protected]<mailto:[email protected]> wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Thanks . I tried W on both sides but stil i get the same error. I also tried to convert re2 to rea but the converter did not work well. Could you please tell me what is this error? Thank you Sijo De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 15:12:55 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco On May 31, 2018, at 9:11 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco BQ_BEGIN On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users BQ_END _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul ________________________________ From: Nek5000-users <[email protected]> on behalf of [email protected] <[email protected]> Sent: Thursday, May 31, 2018 8:12:55 AM To: [email protected] Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco On May 31, 2018, at 9:11 AM, [email protected]<mailto:[email protected]> wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [email protected]<mailto:[email protected]> wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul From: Nek5000-users <[email protected]> on behalf of [email protected] <[email protected]> Sent: Thursday, May 31, 2018 8:12:55 AM To: [email protected] Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco On May 31, 2018, at 9:11 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco BQ_BEGIN On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users BQ_END _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions. Marco On May 31, 2018, at 9:37 AM, [email protected]<mailto:[email protected]> wrote: I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul ________________________________ From: Nek5000-users <[email protected]<mailto:[email protected]>> on behalf of [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Sent: Thursday, May 31, 2018 8:12:55 AM To: [email protected]<mailto:[email protected]> Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco On May 31, 2018, at 9:11 AM, [email protected]<mailto:[email protected]> wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [email protected]<mailto:[email protected]> wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Yes. I see the problem now. it shows there is 1000 elements but all the co ordinates are zero. In fact there is nothing and all the boundary conditions are E. Could you please tell me where i am probably wrong? It was showing correct number of elemnts and the range of domain. Even when i was using exo2nek it was showing the correct numbers. And genmap worked as well. Regards Sijo De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 15:43:20 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions. Marco On May 31, 2018, at 9:37 AM, [ mailto:[email protected] | [email protected] ] wrote: I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul From: Nek5000-users < [ mailto:[email protected] | [email protected] ] > on behalf of [ mailto:[email protected] | [email protected] ] < [ mailto:[email protected] | [email protected] ] > Sent: Thursday, May 31, 2018 8:12:55 AM To: [ mailto:[email protected] | [email protected] ] Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco BQ_BEGIN On May 31, 2018, at 9:11 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco BQ_BEGIN On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
It probably means that the boundary conditions are not correctly set in usrdat(). Can you add a write statement in each line of the do loop to check wether boundary conditions are properly set when running? Also add ‘call exist’ after setting the boundary conditions that way Nek5000 will automatically exit. Marco On May 31, 2018, at 9:51 AM, [email protected]<mailto:[email protected]> wrote: Yes. I see the problem now. it shows there is 1000 elements but all the co ordinates are zero. In fact there is nothing and all the boundary conditions are E. Could you please tell me where i am probably wrong? It was showing correct number of elemnts and the range of domain. Even when i was using exo2nek it was showing the correct numbers. And genmap worked as well. Regards Sijo ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:43:20 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions. Marco On May 31, 2018, at 9:37 AM, [email protected]<mailto:[email protected]> wrote: I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul ________________________________ From: Nek5000-users <[email protected]<mailto:[email protected]>> on behalf of [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Sent: Thursday, May 31, 2018 8:12:55 AM To: [email protected]<mailto:[email protected]> Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco On May 31, 2018, at 9:11 AM, [email protected]<mailto:[email protected]> wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [email protected]<mailto:[email protected]> wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
When I checked the loop I can see that only the bold letter codes are executing in all the iteration. subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo call gen_rea(0) call exit return end Thanks Sijo De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 15:54:04 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file It probably means that the boundary conditions are not correctly set in usrdat(). Can you add a write statement in each line of the do loop to check wether boundary conditions are properly set when running? Also add ‘call exist’ after setting the boundary conditions that way Nek5000 will automatically exit. Marco On May 31, 2018, at 9:51 AM, [ mailto:[email protected] | [email protected] ] wrote: Yes. I see the problem now. it shows there is 1000 elements but all the co ordinates are zero. In fact there is nothing and all the boundary conditions are E. Could you please tell me where i am probably wrong? It was showing correct number of elemnts and the range of domain. Even when i was using exo2nek it was showing the correct numbers. And genmap worked as well. Regards Sijo De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:43:20 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions. Marco BQ_BEGIN On May 31, 2018, at 9:37 AM, [ mailto:[email protected] | [email protected] ] wrote: I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul From: Nek5000-users < [ mailto:[email protected] | [email protected] ] > on behalf of [ mailto:[email protected] | [email protected] ] < [ mailto:[email protected] | [email protected] ] > Sent: Thursday, May 31, 2018 8:12:55 AM To: [ mailto:[email protected] | [email protected] ] Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco BQ_BEGIN On May 31, 2018, at 9:11 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco BQ_BEGIN On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users BQ_END _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
You should output values of i, j, next, ndim and bc(5,j,i,1) for sanity check. Marco On May 31, 2018, at 10:07 AM, [email protected]<mailto:[email protected]> wrote: When I checked the loop I can see that only the bold letter codes are executing in all the iteration. subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo call gen_rea(0) call exit return end Thanks Sijo ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:54:04 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file It probably means that the boundary conditions are not correctly set in usrdat(). Can you add a write statement in each line of the do loop to check wether boundary conditions are properly set when running? Also add ‘call exist’ after setting the boundary conditions that way Nek5000 will automatically exit. Marco On May 31, 2018, at 9:51 AM, [email protected]<mailto:[email protected]> wrote: Yes. I see the problem now. it shows there is 1000 elements but all the co ordinates are zero. In fact there is nothing and all the boundary conditions are E. Could you please tell me where i am probably wrong? It was showing correct number of elemnts and the range of domain. Even when i was using exo2nek it was showing the correct numbers. And genmap worked as well. Regards Sijo ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:43:20 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions. Marco On May 31, 2018, at 9:37 AM, [email protected]<mailto:[email protected]> wrote: I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul ________________________________ From: Nek5000-users <[email protected]<mailto:[email protected]>> on behalf of [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Sent: Thursday, May 31, 2018 8:12:55 AM To: [email protected]<mailto:[email protected]> Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco On May 31, 2018, at 9:11 AM, [email protected]<mailto:[email protected]> wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [email protected]<mailto:[email protected]> wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' write (6,1) j,i,nelt,ndim,bc(5,j,i,1) 1 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' write (6,2) j,i,nelt,ndim,bc(5,j,i,1) 2 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' write (6,3) j,i,nelt,ndim,bc(5,j,i,1) 3 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' write (6,4) j,i,nelt,ndim,bc(5,j,i,1) 4 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' write (6,5) j,i,nelt,ndim,bc(5,j,i,1) 5 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' write (6,6) j,i,nelt,ndim,bc(5,j,i,1) 6 format(i4,i4,i4,i4,7f20.8) else cbc(j,i,1)='E ' write (6,7) j,i,nelt,ndim,bc(5,j,i,1) 7 format(i4,i4,i4,i4,7f20.8) endif enddo enddo call gen_rea(0) call exit return end c----------------------------------------------------------------------- i used this and only bold lines of code are executed at every time step and a small piece of the results is shown below 1 9991000 3 0.00000000 2 9991000 3 0.00000000 3 9991000 3 0.00000000 4 9991000 3 0.00000000 5 9991000 3 0.00000000 6 9991000 3 0.00000000 Thank you Sijo De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 16:12:12 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file You should output values of i, j, next, ndim and bc(5,j,i,1) for sanity check. Marco On May 31, 2018, at 10:07 AM, [ mailto:[email protected] | [email protected] ] wrote: When I checked the loop I can see that only the bold letter codes are executing in all the iteration. subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo call gen_rea(0) call exit return end Thanks Sijo De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:54:04 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file It probably means that the boundary conditions are not correctly set in usrdat(). Can you add a write statement in each line of the do loop to check wether boundary conditions are properly set when running? Also add ‘call exist’ after setting the boundary conditions that way Nek5000 will automatically exit. Marco BQ_BEGIN On May 31, 2018, at 9:51 AM, [ mailto:[email protected] | [email protected] ] wrote: Yes. I see the problem now. it shows there is 1000 elements but all the co ordinates are zero. In fact there is nothing and all the boundary conditions are E. Could you please tell me where i am probably wrong? It was showing correct number of elemnts and the range of domain. Even when i was using exo2nek it was showing the correct numbers. And genmap worked as well. Regards Sijo De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:43:20 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions. Marco BQ_BEGIN On May 31, 2018, at 9:37 AM, [ mailto:[email protected] | [email protected] ] wrote: I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul From: Nek5000-users < [ mailto:[email protected] | [email protected] ] > on behalf of [ mailto:[email protected] | [email protected] ] < [ mailto:[email protected] | [email protected] ] > Sent: Thursday, May 31, 2018 8:12:55 AM To: [ mailto:[email protected] | [email protected] ] Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco BQ_BEGIN On May 31, 2018, at 9:11 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco BQ_BEGIN On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users BQ_END _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
you have to add the print statement before you enter the if statements. Marco On May 31, 2018, at 10:25 AM, [email protected]<mailto:[email protected]> wrote: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' write (6,1) j,i,nelt,ndim,bc(5,j,i,1) 1 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' write (6,2) j,i,nelt,ndim,bc(5,j,i,1) 2 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' write (6,3) j,i,nelt,ndim,bc(5,j,i,1) 3 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' write (6,4) j,i,nelt,ndim,bc(5,j,i,1) 4 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' write (6,5) j,i,nelt,ndim,bc(5,j,i,1) 5 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' write (6,6) j,i,nelt,ndim,bc(5,j,i,1) 6 format(i4,i4,i4,i4,7f20.8) else cbc(j,i,1)='E ' write (6,7) j,i,nelt,ndim,bc(5,j,i,1) 7 format(i4,i4,i4,i4,7f20.8) endif enddo enddo call gen_rea(0) call exit return end c----------------------------------------------------------------------- i used this and only bold lines of code are executed at every time step and a small piece of the results is shown below 1 9991000 3 0.00000000 2 9991000 3 0.00000000 3 9991000 3 0.00000000 4 9991000 3 0.00000000 5 9991000 3 0.00000000 6 9991000 3 0.00000000 Thank you Sijo ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 16:12:12 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file You should output values of i, j, next, ndim and bc(5,j,i,1) for sanity check. Marco On May 31, 2018, at 10:07 AM, [email protected]<mailto:[email protected]> wrote: When I checked the loop I can see that only the bold letter codes are executing in all the iteration. subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo call gen_rea(0) call exit return end Thanks Sijo ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:54:04 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file It probably means that the boundary conditions are not correctly set in usrdat(). Can you add a write statement in each line of the do loop to check wether boundary conditions are properly set when running? Also add ‘call exist’ after setting the boundary conditions that way Nek5000 will automatically exit. Marco On May 31, 2018, at 9:51 AM, [email protected]<mailto:[email protected]> wrote: Yes. I see the problem now. it shows there is 1000 elements but all the co ordinates are zero. In fact there is nothing and all the boundary conditions are E. Could you please tell me where i am probably wrong? It was showing correct number of elemnts and the range of domain. Even when i was using exo2nek it was showing the correct numbers. And genmap worked as well. Regards Sijo ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:43:20 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions. Marco On May 31, 2018, at 9:37 AM, [email protected]<mailto:[email protected]> wrote: I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul ________________________________ From: Nek5000-users <[email protected]<mailto:[email protected]>> on behalf of [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Sent: Thursday, May 31, 2018 8:12:55 AM To: [email protected]<mailto:[email protected]> Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco On May 31, 2018, at 9:11 AM, [email protected]<mailto:[email protected]> wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE ________________________________ De: "nek5000-users" <[email protected]<mailto:[email protected]>> À: "nek5000-users" <[email protected]<mailto:[email protected]>> Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco On May 31, 2018, at 8:50 AM, [email protected]<mailto:[email protected]> wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [email protected]<mailto:[email protected]> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Yes. The same results. Could you please tell me why there is a 5 on the bc(5,j,i,1)? And the value of bc(5,j,i,1) was zero for all the iteration. Thank you De: "nek5000-users" <[email protected]> À: "nek5000-users" <[email protected]> Envoyé: Jeudi 31 Mai 2018 16:28:59 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file you have to add the print statement before you enter the if statements. Marco On May 31, 2018, at 10:25 AM, [ mailto:[email protected] | [email protected] ] wrote: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' write (6,1) j,i,nelt,ndim,bc(5,j,i,1) 1 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' write (6,2) j,i,nelt,ndim,bc(5,j,i,1) 2 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' write (6,3) j,i,nelt,ndim,bc(5,j,i,1) 3 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' write (6,4) j,i,nelt,ndim,bc(5,j,i,1) 4 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' write (6,5) j,i,nelt,ndim,bc(5,j,i,1) 5 format(i4,i4,i4,i4,7f20.8) elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' write (6,6) j,i,nelt,ndim,bc(5,j,i,1) 6 format(i4,i4,i4,i4,7f20.8) else cbc(j,i,1)='E ' write (6,7) j,i,nelt,ndim,bc(5,j,i,1) 7 format(i4,i4,i4,i4,7f20.8) endif enddo enddo call gen_rea(0) call exit return end c----------------------------------------------------------------------- i used this and only bold lines of code are executed at every time step and a small piece of the results is shown below 1 9991000 3 0.00000000 2 9991000 3 0.00000000 3 9991000 3 0.00000000 4 9991000 3 0.00000000 5 9991000 3 0.00000000 6 9991000 3 0.00000000 Thank you Sijo De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 16:12:12 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file You should output values of i, j, next, ndim and bc(5,j,i,1) for sanity check. Marco BQ_BEGIN On May 31, 2018, at 10:07 AM, [ mailto:[email protected] | [email protected] ] wrote: When I checked the loop I can see that only the bold letter codes are executing in all the iteration. subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo call gen_rea(0) call exit return end Thanks Sijo De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:54:04 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file It probably means that the boundary conditions are not correctly set in usrdat(). Can you add a write statement in each line of the do loop to check wether boundary conditions are properly set when running? Also add ‘call exist’ after setting the boundary conditions that way Nek5000 will automatically exit. Marco BQ_BEGIN On May 31, 2018, at 9:51 AM, [ mailto:[email protected] | [email protected] ] wrote: Yes. I see the problem now. it shows there is 1000 elements but all the co ordinates are zero. In fact there is nothing and all the boundary conditions are E. Could you please tell me where i am probably wrong? It was showing correct number of elemnts and the range of domain. Even when i was using exo2nek it was showing the correct numbers. And genmap worked as well. Regards Sijo De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:43:20 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Can you add ‘call gen_rea(0)’ after setting the boundary conditions in usrdat()? It will generate a *.rea file with all boundary conditions. Marco BQ_BEGIN On May 31, 2018, at 9:37 AM, [ mailto:[email protected] | [email protected] ] wrote: I generated again it didnt work. I will explain what I did so far. I made a cube fluid mesh in ICEM. Then I gave B.Cs to the cube as follows : outlet = Sideset no : 1, inlet = Sideset no : 5 , Wall_up = Sideset no:4 ,Wall_down = Sideset no:3 , P_Wall_Right =Side_set 6, P_wall_left = Sideset no: 2 After that I exported the mesh from ICEM to exodus.exo format file. Then using exo2nek tool from NEK5000, I converted the above file to exodus.re2 file. (Then I tried to convert into rea file but thrown some errors). Then I mapped the file into exodus.ma2 file. Then from example Turbulent channel I took a .par file to give parameters. Now I also given the B.Cs through the .usr file. as follows: c----------------------------------------------------------------------- subroutine usrdat include 'SIZE' include 'TOTAL' do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='O ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.5) then cbc(j,i,1)='V ' elseif(bc(5,j,i,1).eq.6) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo return end c----------------------------------------------------------------------- Then in my folder I have .ma2,.re2,.par,.usr files to run this case and when i run the case I get an error shown before. Could you please tell me, if therer is anything wrong? Thank you De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 15:22:49 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file Did you generate a new map file after changing the BCs? This matters when switching periodic bcs on or off... Paul From: Nek5000-users < [ mailto:[email protected] | [email protected] ] > on behalf of [ mailto:[email protected] | [email protected] ] < [ mailto:[email protected] | [email protected] ] > Sent: Thursday, May 31, 2018 8:12:55 AM To: [ mailto:[email protected] | [email protected] ] Subject: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I do not think this method supports periodic boundary conditions. You will have to replace the periodic boundary conditions with wall boundary conditions and see it is runs. Marco BQ_BEGIN On May 31, 2018, at 9:11 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Marco, I tried and it compiled . But before starting the time step it failed. Its a very simple case, the water flowing throgh a cube. So I have inlet, outlet, walls on upside and bottom and periodic conditions on side walls. I get this error: Matrix: 0 aa 6 6 6 0 aa 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 aa -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 aa 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 aa 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 aa 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 aa 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 bb 6 6 6 0 bb 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 1.66667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 4.16667E-02 0.00000E+00 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 8.33333E-03 0.00000E+00 0 bb 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Matrix: 0 Aeig 6 6 6 0 Aeig 8.33333E+01 -4.87842E+01 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0 Aeig -4.87842E+01 8.66667E+01 -4.87842E+01 7.11752E+00 -1.66667E+00 0.00000E+00 0 Aeig 0.00000E+00 -4.87842E+01 8.33333E+01 -4.16667E+01 7.11752E+00 0.00000E+00 0 Aeig 0.00000E+00 7.11752E+00 -4.16667E+01 8.33333E+01 -4.87842E+01 0.00000E+00 0 Aeig 0.00000E+00 -1.66667E+00 7.11752E+00 -4.87842E+01 Infinity -Infinity 0 Aeig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 -Infinity Infinity Matrix: 0 Deig 1 6 6 0 Deig 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 0.00000E+00 Error in generalev, info= 12 6 -6 an error occured: dying ... Could you please tell me why? Thank you Sijo GEORGE De: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > À: "nek5000-users" < [ mailto:[email protected] | [email protected] ] > Envoyé: Jeudi 31 Mai 2018 14:52:40 Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file I specify the boundary conditions in the usrdat subroutine using the following piece of code do i=1,nelt do j=1,2*ndim if(bc(5,j,i,1).eq.1) then cbc(j,i,1)='mv ' elseif(bc(5,j,i,1).eq.2) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.3) then cbc(j,i,1)='W ' elseif(bc(5,j,i,1).eq.4) then cbc(j,i,1)='W ' else cbc(j,i,1)='E ' endif enddo enddo Marco BQ_BEGIN On May 31, 2018, at 8:50 AM, [ mailto:[email protected] | [email protected] ] wrote: Hi Neks, I did the conversion of a mesh from ICEM to exodus file then to re2 file. But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format. So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format. Thank you _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] [ https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users | https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users ] BQ_END _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users _______________________________________________ Nek5000-users mailing list [ mailto:[email protected] | [email protected] ] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users BQ_END _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
participants (1)
nek5000-users@lists.mcs.anl.gov
