Hello everybody, I am running into problems at the outset. I wonder if someone could guide me as to how to compile makenek I get the following error when typing makenek 07 mexico:/home/rpacheco/nek5_svn/trunk/nek > makenek usage: makenek [.usr filename|clean] thank you! Rafael
Hi Rafael, Did you try: $ makenek pipeflow3d where 'pipeflow3d' is your current case. Johan Quoting Rafael Pacheco <[email protected]>:
Hello everybody,
thank you! Rafael _______________________________________________ Nek5000-users mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
---------------------------------------------------------------- This message was sent using IMP, the Internet Messaging Program.
Hi Johan, obviously I am not knowledgeable on the use of this software, but thanks for your help. I have makenek in the /trunk/nek directory, so I would be grateful if you guide me step by step on how to run an example, or a document that shows how to do this. thanks! Rafael
Hi Rafael,
Did you try:
Johan
Hello everybody,
-- Rafael -------------------------------------------------------------------- Department of Mathematics and Statistics Arizona State University P.O. Box 871804 Tempe, Arizona 85287-1804 Email: [email protected] http://math.la.asu.edu/~rpacheco --------------------------------------------------------------------
check this: https://nek5000.mcs.anl.gov/index.php/Guided_Tutorial hth, Stefan On Sep 26, 2009, at 4:01 AM, Rafael Pacheco wrote:
Hello everybody,
Stefan, thanks! Rafael
hth, Stefan
Hello everybody,
participants (3)
johan@mech.kth.se -
Rafael Pacheco -
stefanke
