Re: [petsc-dev] Preconditioner for Schur complement (pcfieldsplit)
On Tue, Mar 29, 2011 at 13:12, Thomas Witkowski < [email protected]> wrote:
PCFieldsplitSchurPrecondition seems to do what I want. But how to create the matrix for the preconditioner? I'm a little bit confused about it because the matrix/operator S acts on an index range that does not start from 0 and is not continuous, because each rank owns only some parts of the interior domain boundaries.
We do not currently have a way to set attributes on a "submatrix" that you will extract in the future. You can implement MatGetSubMatrix to return your special matrix for that block when called with that pair of ISs. Or you can use MatNest for the preconditioning matrix, it is frequently a good storage format when doing fieldsplit and you can use it unintrusively.
participants (1)
Jed Brown
