Re: [petsc-dev] upcoming release and testing [v2]
Thanks! I pushed some fixes to rmills/doc-add-rmills-to-user-manual. Satish On Fri, 6 Apr 2018, Richard Tran Mills wrote:
Hi Satish,
I decided that I don't have time to polish things as much as I'd like, so I'll make the significant user manual edit I had in mind after the release. It's something that can wait.
I do have some minor doc changes to go into master for the release. I've tested these on my laptop to make sure they didn't break building the manual or man pages, but I suppose you should do a doc build cycle. Please merge in
rmills/doc-rmills-performance-section-minor-edit rmills/doc-update-matcreateseqaijmkl-man-page
With Barry's permission, I also made changes on these branches to add myself to the user manual author list and the website:
rmills/doc-add-rmills-to-user-manual rmills/webpage-add-rmills
Could you please make sure that I made edits in all the right places for the above two branches, and then merge in for the release?
Thanks, Richard
On Thu, Apr 5, 2018 at 1:04 PM, Balay, Satish <[email protected]> wrote:
Sure - we can push doc changes without going through the test cycle [just a doc build cycle]
thanks, Satish
On Thu, 5 Apr 2018, Richard Tran Mills wrote:
Hi Satish,
I'm working on right now on some edits to part of the "Performance Turning" part of the manual. If I can get these edits to a state I'm happy with, I'd like them to go in the release, but I'm not sure if I will have them ready before this evening.
--Richard
On Thu, Apr 5, 2018 at 5:58 AM, Balay, Satish <[email protected]> wrote:
All,
master builds have been clean for the past 2 days [except for some timeouts]
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/ 2018/04/04/master.html
However next is still not clean [slightly better than previous build]
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/ 2018/04/05/next.html
[i.e the following branches still need fixes]
origin/knepley/fix-dm-gmg origin/knepley/fix-ex62-tests origin/knepley/fix-fe-bd-integral origin/knepley/fix-fe-vector-spaces origin/knepley/fix-snes-ex69 origin/tisaac/feature-dmfield
I have the following branches in queue for master [via next-tmp - these builds will start soon]
origin/balay/update-petsc4py-pre-39 origin/dalcinl/mat-getset-ops origin/jczhang/fix-vecscatter-msg-logging
If next-tmp is clean - I can spin the release tarball later today [after merging them to master]
Or if there are other branches [that are clean] - that should go into release - let me know. We'll either have to wait one more day [for these branches to go through next/next-tmp - or I can schedule another next-tmp build later today (with additional branches) - if they are ready by 3:30pm CST]
If I do not hear back about additional branches, and next-tmp is clean - will spin the release tarball later today.
Thanks, Satish
participants (1)
Satish Balay
