Re: [petsc-dev] nested timers transfers and reductions
Thanks Barry, that looks good! Chris dr. ir. Christiaan Klaij | Senior Researcher | Research & Development MARIN | T +31 317 49 33 44 | mailto:[email protected] | http://www.marin.nl MARIN news: http://www.marin.nl/web/News/News-items/New-correction-procedure-for-shallow... ________________________________________ From: Smith, Barry F. <[email protected]> Sent: Monday, April 09, 2018 11:51 PM To: Klaij, Christiaan Cc: [email protected]; Koos Huijssen Subject: Re: nested timers transfers and reductions Hopefully all these problems are resolved with https://bitbucket.org/petsc/petsc/pull-requests/925/fix-some-missing-functio... Barry
On Apr 9, 2018, at 4:37 AM, Klaij, Christiaan <[email protected]> wrote:
Hi Barry,
I've put the functions and fortran bindings in the attached files. In our code, we use them as follows:
CALL mpi_bcast(value,1,MPI_LOGICAL,iproc,MPI_COMM_WORLD,ier) IF(ier/=0) CALL tracing_abort('ERROR in bcast logical root !')
IF (iproc==thisprocess) THEN ier = PetscAdminSend(1*(nprocesses-1),MPI_LOGICAL) ELSE ier = PetscAdminRecv(1,MPI_LOGICAL) END IF
I also noted that you changed the treshold from 0.1% to 0.01%, so I tried to change it as a user with PetscLogSetThreshold, but this function seems not accessible to users (and there's no fortran version or manual page).
Chris
MARIN news: http://www.marin.nl/web/News/News-items/Kom-zaterdag-10-november-naar-de-ope...
________________________________________ From: Smith, Barry F. <[email protected]> Sent: Saturday, April 07, 2018 5:36 PM To: Klaij, Christiaan Cc: [email protected]; Koos Huijssen Subject: Re: nested timers transfers and reductions
On Apr 6, 2018, at 5:22 AM, Klaij, Christiaan <[email protected]> wrote:
Hi Barry,
In our version of the nested timers, we had the functions PetscAdminSend, PetscAdminRecv and PetscAdminReduce. So I was expecting to find them at the end of the file petsc-3.8.4/src/sys/logging/xmllogevent.c but apparently you (re)moved them?
I do not remember why I would have removed these functions. If you can send a patch that would return them I would gladly try to get them working with PETSc again.
Barry
We basically used these functions to fill the transfer(GiB/s) and reductions/s columns of the log just like we use PetscLogFlops to fill the compute(Mflops) column for our registered events.
How should I do this with the petsc version of the nested timers?
Chris
MARIN news: http://www.marin.nl/web/News/News-items/Application-of-potential-flow-method...
<petsc_MPIadminF.F90><petsc_MPIadmin.c>
participants (1)
Klaij, Christiaan
