TSComputeRHSJacobianConstant issue
Hi all, I'm running into problems with TS with a time independent, linear rhs. Following the user's manual, I use ierr=TSSetProblemType(ts, TS_LINEAR);CHKERRQ(ierr); ierr=TSSetRHSFunction(ts, 0, TSComputeRHSFunctionLinear, 0);CHKERRQ(ierr); ierr=TSSetRHSJacobian(ts, mat, mat, TSComputeRHSJacobianConstant, 0);CHKERRQ(ierr); But running the code I get: [dmeiser@ivyamd src]$ ./sd -ts_monitor -snes_monitor -ksp_monitor_true_residual -snes_converged_reason -ts_type beuler -ts_max_steps 20 TS dt 0.01 time 0. 0 SNES Function norm 1.433485640883e+00 0 KSP preconditioned resid norm 1.433485640883e-02 true resid norm 1.433485640883e+00 ||r(i)||/||b|| 1.000000000000e+00 1 KSP preconditioned resid norm 6.528150237447e-18 true resid norm 6.122666587510e-16 ||r(i)||/||b|| 4.271173992185e-16 1 SNES Function norm 1.419007435910e+02 Nonlinear solve converged due to CONVERGED_ITS iterations 1 1 TS dt 0.01 time 0.01 0 SNES Function norm 1.433342292319e+02 Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0 [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE, increase -ts_max_snes_failures or make negative to attempt recovery [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: pre-tsfc-330-gda8116b GIT Date: 2016-02-23 15:17:17 -0600 [0]PETSC ERROR: ./sd on a cplx named ivyamd.txcorp.com by dmeiser Fri Feb 26 11:46:29 2016 [0]PETSC ERROR: Configure options --with-scalar-type=complex --with-x=0 --with-debugging=1 --with-ssl=0 --with-fortran-kernels=0 --with-pthread=0 --download-fftw=1 --with-mpi=1 --download-mpich=1 --with-mpiuni-fortran-binding=0 --with-fortran-interfaces [0]PETSC ERROR: #1 TSStep() line 3346 in /scr_ivyamd/dmeiser/SD/petsc/src/ts/interface/ts.c [0]PETSC ERROR: #2 TSSolve() line 3544 in /scr_ivyamd/dmeiser/SD/petsc/src/ts/interface/ts.c [0]PETSC ERROR: #3 main() line 63 in /scr_ivyamd/dmeiser/SD/src/sd.c [0]PETSC ERROR: PETSc Option Table entries: [0]PETSC ERROR: -ksp_monitor_true_residual [0]PETSC ERROR: -snes_converged_reason [0]PETSC ERROR: -snes_monitor [0]PETSC ERROR: -ts_max_steps 2 [0]PETSC ERROR: -ts_monitor [0]PETSC ERROR: -ts_type beuler [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] application called MPI_Abort(MPI_COMM_WORLD, 91) - process 0 [unset]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 91) - process 0 It seems that the linear system is being solved just fine. But apparently it's the wrong linear problem because the SNES function norm doesn't decrease. I think the problem might be related to the following behaviour of `scr/ts/examples/tutorials/ex3.c`: [dmeiser@ivyamd tutorials]$ ./ex3 -nox -ts_type beuler -ts_max_steps 2 -ksp_converged_reason -snes_monitor Solving a linear TS problem on 1 processor Timestep 0: step size = 0.000143637, time = 0., 2-norm error = 1.01507e-15, max norm error = 3.10862e-15 0 SNES Function norm 2.018485956680e+03 Linear solve converged due to CONVERGED_RTOL iterations 1 1 SNES Function norm 1.207665524289e+05 Timestep 1: step size = 0.000143637, time = 0.000143637, 2-norm error = 0.000599907, max norm error = 0.000863771 0 SNES Function norm 1.195422385486e+05 Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0 PCSETUP_FAILED due to FACTOR_NUMERIC_ZEROPIVOT [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE, increase -ts_max_snes_failures or make negative to attempt recovery [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: pre-tsfc-330-gda8116b GIT Date: 2016-02-23 15:17:17 -0600 [0]PETSC ERROR: ./ex3 on a cplx named ivyamd.txcorp.com by dmeiser Fri Feb 26 11:36:28 2016 [0]PETSC ERROR: Configure options --with-scalar-type=complex --with-x=0 --with-debugging=1 --with-ssl=0 --with-fortran-kernels=0 --with-pthread=0 --download-fftw=1 --with-mpi=1 --download-mpich=1 --with-mpiuni-fortran-binding=0 --with-fortran-interfaces [0]PETSC ERROR: #1 TSStep() line 3346 in /scr_ivyamd/dmeiser/SD/petsc/src/ts/interface/ts.c [0]PETSC ERROR: #2 TSSolve() line 3544 in /scr_ivyamd/dmeiser/SD/petsc/src/ts/interface/ts.c [0]PETSC ERROR: #3 main() line 216 in /scr_ivyamd/dmeiser/SD/petsc/src/ts/examples/tutorials/ex3.c [0]PETSC ERROR: PETSc Option Table entries: [0]PETSC ERROR: -ksp_converged_reason [0]PETSC ERROR: -nox [0]PETSC ERROR: -snes_monitor [0]PETSC ERROR: -ts_max_steps 2 [0]PETSC ERROR: -ts_type beuler [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] application called MPI_Abort(MPI_COMM_WORLD, 91) - process 0 [unset]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 91) - process 0 I'm aware of Jed's commit e1244c6 which I thought was supposed to enable constant linear rhs without IFunction and IJacobian. Note that e1244c6 also added tests that apparently produced very different output (see e.g. src/ts/examples/tutorials/output/ex3_4.out). Is constant rhs without IFunction and IJacobian no longer supported or did it just breat at some point? Do I need to call TSRHSJacobianSetReuse in addition to the lines of code above? Is it better to treat such systems using TSComputeIFunctionLinear and TSComputeIJacobianConstant? Thanks, Dominic -- Dominic Meiser Tech-X Corporation - 5621 Arapahoe Avenue - Boulder, CO 80303
participants (1)
Dominic Meiser
