On Jul 3, 2016, at 11:59 AM, Mark Adams <[email protected]> wrote:
Thanks, I saw that. ASM converges slower than SOR :(
You can try -mg_levels_pc_asm_local_type multiplicative that Matt added, but you probably need to switch to GMRES since I don't think Matt did a symmetric version of it.
On Sun, Jul 3, 2016 at 6:50 PM, Barry Smith <[email protected]> wrote:
Here is the problem:
if (!sz) { IS nis; ierr = ISCreateGeneral(PETSC_COMM_SELF, 0, NULL, PETSC_COPY_VALUES, &nis);CHKERRQ(ierr); ierr = PCASMSetLocalSubdomains(subpc, 1, NULL, &nis);CHKERRQ(ierr); ierr = ISDestroy(&nis);CHKERRQ(ierr);
It was setting the first IS when it should be setting the second. When I run after this change I get reasonable results.
0 KSP Residual norm 2.469493285658e+02 1 KSP Residual norm 1.335901394170e+01 2 KSP Residual norm 5.623002716761e-01 3 KSP Residual norm 5.201650164984e-02 4 KSP Residual norm 3.763050190737e-03 5 KSP Residual norm 3.024410926322e-04 Linear solve converged due to CONVERGED_RTOL iterations 5 0 KSP Residual norm 2.469493285658e-03 1 KSP Residual norm 1.335901394170e-04 2 KSP Residual norm 5.623002716761e-06 3 KSP Residual norm 5.201650164983e-07 4 KSP Residual norm 3.763050190737e-08 5 KSP Residual norm 3.024410926322e-09 Linear solve converged due to CONVERGED_RTOL iterations 5 0 KSP Residual norm 2.469493285658e-08 1 KSP Residual norm 1.335901394170e-09 2 KSP Residual norm 5.623002716761e-11 3 KSP Residual norm 5.201650164984e-12 4 KSP Residual norm 3.763050190737e-13 5 KSP Residual norm 3.024410926322e-14
On Jul 3, 2016, at 10:40 AM, Mark Adams <[email protected]> wrote:
Barry,
GAMG must be setting up the ASM incorrectly, on empty processors, when using the aggregates. In asm.c, I see that osm->is_local is NULL for empty processors, and this causes a problem when this branch is taken by less than 8 processes (of 8):
if (osm->is_local) { // asm.c:282 .... ierr = VecScatterCreate(vec,osm->is_local[i],osm->y_local[i],isl,&osm->prolongation[i]);CHKERRQ(ierr);
I get an error "MPI_Allreduce() called in different locations (code lines) on different processors ", because "vec" here is global. This gamg.c code must not be correct:
if (!sz) { IS is; ierr = ISCreateGeneral(PETSC_COMM_SELF, 0, NULL, PETSC_COPY_VALUES, &is);CHKERRQ(ierr); ierr = PCASMSetLocalSubdomains(subpc, 1, &is, NULL);CHKERRQ(ierr); ierr = ISDestroy(&is);CHKERRQ(ierr); } else { .... }
I will look into why osm->is_local seems to be NULL here when it should have an empty IS.
participants (1)
Barry Smith
