Re: [petsc-dev] Regression tests
On Sat, Jul 28, 2012 at 6:53 AM, Gerard Gorman <[email protected]>wrote:
Slightly off topic - but I have Buildbot set up locally to keep an eye on petsc-dev and various branches of petsc that I care about (if you are curious see http://stereolab.ese.ic.ac.uk:8080/waterfall - knock yourself out with the force build button if you wish)
Because this is a bot, 99% of time I only care about "pass", "fail" ($? != 0 is counted as a fail), "warning". For the testharness in our own application code we just parse the output of unit tests for "pass", "fail" and "warning" and list the tests that gave a warning or fail at the end so a developer can take a closer look. I would like to do a similar grepping for PETSc tests. Are the tests messages standardised so I can do this? At first glance I have:
"pass" == "run successfully with" "warning" == "Possible problem with" "fail" == "mpiexec not found" or $? != 0
I think you want http://petsc.cs.iit.edu/petsc/petsc-dev/annotate/c11230be07bd/bin/maint/chec... for builds, and what you have for tests. Matt Cheers
Gerard
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
