Give a try. When using MPICH2, PETSc just passes "--with-mpi=PATH_TO_MPI" and ML get it right. Perhaps ML have some trouble with OpenMPI, I've never tried. If you built OpenMPI yourself and with shared libs, do not forget to define LD_LIBRARY_PATH to point to the dir with the OpenMPI libs. If not, some configure test of ML could fail, and then MPI is assumed to be absent. On 3/21/08, Jed Brown <[email protected]> wrote:
On Fri 2008-03-21 19:31, Lisandro Dalcin wrote:
Mmm... I believe this is a configuration issue... if ML_MPI were defined, then ML_USR_COMM should be MPI_Comm. But the problem is perhaps on the ML side, not the PETSc side.
"ml_common.h" #define ML_MPI if macro HAVE_MPI is defined. In turn HAVE_MPI is at "ml_config.h", and that file is surelly generated by ML configure script. For some reason ML's configure failed to found MPI with the command line stuff PETSc pass to it. Look at the 'config.log' file inside the "ml-5.0" dir to find what happened.
From the ML docs, it looks like ML's configure expects --with-mpi-compilers if it is building with MPI. I modified config/PETSc/packages/ml.py to include this option and I'll let you know if it fixes the problem.
Jed
-- Lisandro Dalc�n --------------- Centro Internacional de M�todos Computacionales en Ingenier�a (CIMEC) Instituto de Desarrollo Tecnol�gico para la Industria Qu�mica (INTEC) Consejo Nacional de Investigaciones Cient�ficas y T�cnicas (CONICET) PTLC - G�emes 3450, (3000) Santa Fe, Argentina Tel/Fax: +54-(0)342-451.1594
participants (1)
Lisandro Dalcin
