Re: [petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
Hello, Did you copy the files from https://gitlab.com/petsc/datafiles <https://gitlab.com/petsc/datafiles> before the make check? cfd.1.10 is not part of https://gitlab.com/petsc/petsc <https://gitlab.com/petsc/petsc>, so you either need to copy the files from the datafiles repository, or remove the --DATAFILESPATH=/home/sagitter/rpmbuild/BUILD/petsc-3.15.4/petsc-3.15.4/share/petsc/datafiles configure option. Thanks, Pierre
On 12 Sep 2021, at 6:02 PM, Antonio T. sagitter <[email protected]> wrote:
Hi all.
This error is repeated when the tests are compiled in PETSc-3.15.4 compilation: https://paste.in/MhdNjf
This happens in Fedora 34 x86_64 with gcc-11.2.1
make.log and configure.log are attached -- --- Antonio Trande Fedora Project mailto: [email protected] GPG key: 0x29FBC85D7A51CC2F GPG key server: https://keyserver1.pgp.com/ <make_configure.zip><OpenPGP_0x29FBC85D7A51CC2F.asc>
participants (1)
Pierre Jolivet
