Re: [petsc-dev] how to print with PescPrintf a PetscScalar value?
sorry... previously I had tried with a cast ... something like (PetscInt)sum... I knew PetscGetReal is a function... but I just replaced PetscInt with PetscGetReal... without moving parenthesis thanks again Luigia Ambrosio Se la gente ferisce è perchè tu sei migliore e lo capisce bene! - Tiziano Ferro Il giorno 04/lug/2012, alle ore 10:20, Jed Brown ha scritto:
On Wed, Jul 4, 2012 at 12:15 AM, Luigia Ambrosio <[email protected]> wrote: this is the source code (very simple) Vec x; PetscInt n = 10; PetscErrorCode ierr; PetscScalar one = 1.0;
ierr = VecCreateMPI(PETSC_COMM_WORLD, PETSC_DECIDE, n, &x);CHKERRQ(ierr); ierr = VecSet(x,one);CHKERRQ(ierr); PetscScalar sum=0.0; ierr = VecSum(x,&sum);CHKERRQ(ierr); ierr = PetscPrintf(PETSC_COMM_WORLD,"sum %f\n",(PetscRealPart)sum);
Use PetscRealPart(sum), it is a function, not a type.
CHKERRQ(ierr); puts("");
This puts will be issued by every process, leading to messy output, especially for larger runs. Just add a second \n to the string passed to PetscPrintf() if you want another newline.
and this is the error message I get trying make myex error: 'PetscRealPart' was not declared in this scope
this is how I compile myex myex: myex.o chkopts -${CLINKER} -o myex myex.o ${PETSC_VEC_LIB} ${RM} -f myex.o
I have petsc 3.3 developer version
Luigia Ambrosio
Il giorno 04/lug/2012, alle ore 09:58, Jed Brown ha scritto:
On Tue, Jul 3, 2012 at 11:53 PM, Luigia Ambrosio <[email protected]> wrote: It seems I don't have this function. I checked my configuring options, in particular --with-scalar-type=complex
Which version of PETSc? Can you send the full error message?
so I'm sure that a PetscScalar variable is handled as a complex number. I tried to use the PetscRealPart but it says: error: 'PetscRealPart' was not declared in this scope
I included also the header "petscmat.h" but there isn't defined this function. It seems that I don't include the right header, I googled it but I didn't find it. Which header shiuld I include?
That header includes petscmath.h (which you should not include directly).
thanks
Luigia Ambrosio
Il giorno 04/lug/2012, alle ore 09:28, Jed Brown ha scritto:
On Tue, Jul 3, 2012 at 11:26 PM, Luigia Ambrosio <[email protected]> wrote: Is there a function already avilable to get the real part of a petscscalar value?
PetscRealPart() and PetscImaginaryPart()
participants (1)
Luigia Ambrosio
