Understanding Vecscatter with Kokkos Vecs
I'm trying to understand how VecScatters work with GPU-native Kokkos Vecs. Specifically, I'm interested in what will happen in code like in src/vec/vec/tests/ex22.c, ierr = VecScatterCreate(x,is1,y,is2,&ctx);CHKERRQ(ierr); (from https://gitlab.com/petsc/petsc/-/blob/master/src/vec/vec/tests/ex22.c#L44 <https://gitlab.com/petsc/petsc/-/blob/master/src/vec/vec/tests/ex22.c#L44>) Here, x and y can be set to type KOKKOS using -vec_type kokkos at the command line. But is1 and is2 are (I think), always CPU/host data. Assuming that the scatter itself can happen on the GPU, the indices must make it to the device somehow - are they copied there when the scatter is created? Is there a way to create the scatter using indices already on the GPU (Maybe using SF more directly)?
participants (1)
Patrick Sanan
