Re: Adding Harwell-Boeing support in PETSc?
Barry, I get Harwell-Boeing matrices from Matrix Market repository, where each HB matrix is provided by both Matrix Market and HB format. HB format takes smaller space though. I never used HB format. I wrote the code that convert MM format into petsc binary, which is stored under ~/datafiles/matrices/MtxMarket. Hong On Tue, 5 Apr 2005, Barry Smith wrote:
My understanding is that MatrixMarket format is different from Harwell-Boeing?
I could not find a Harwell-Boeing loader in src/mat/examples/tests (though there is a writer). Does anyone have C (PETSc?) code to read in Harwell-Boeing? If so we could merge it into the MatrixMarket (coordiate storage) reader code and then (with a command line switch) read in either format and dump in PETSc format?
Barry
On Tue, 5 Apr 2005, Victor Eijkhout wrote:
At 10:32 AM -0500 4/5/05, Hong Zhang wrote:
We have code that read MatrixMarket format, and write into a petsc binary file. Then you can use petsc MatLoad() for viewing or computation.
I'm interested in this too. I wrote my own version. Maybe a good idea to add this to the petsc distribution?
participants (1)
Hong Zhang
