Re: [petsc-dev] Are pipelines down?
On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <[email protected]> wrote:
For forks - a member of the developer group needs to start a new pipeline. (after basic checks on the changes)
The original pipeline just sat pending in the source check, so I cancelled it. I created a new pipeline, but it is just sitting pending in the source check https://gitlab.com/danfinn/petsc/-/pipelines/269297070 Why will this not run? Thanks, Matt
Satish
On Thu, 11 Mar 2021, Jed Brown wrote:
Says the pipeline was canceled. The branch comes from a fork so it should need approval to run.
https://gitlab.com/petsc/petsc/-/merge_requests/3707
Matthew Knepley <[email protected]> writes:
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ < http://www.cse.buffalo.edu/~knepley/>
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
