Re: [petsc-dev] BuildSystem help needed
On Sat, Jul 23, 2011 at 3:03 AM, Barry Smith <[email protected]> wrote:
Matt,
When a user provides --download-packagename for any package that does not support --download- configure silently ignores their request leading the user to think that it actually did download the package.
This is because in package.py there is the code
def checkDownload(self, requireDownload = 1): '''Check if we should download the package, returning the install directory or the empty string indicating installation''' if not self.download: return ''
I naively thought I could simple add a check if the user provided --download-package but self.download was not supported it would error out with a useful error message. That proved impossible.
Impossible!!! This is ridiculous. Either I have no idea what you want, or this is a serious case of Not Invented Here syndrome (also I did not even write these lines of code). @@ -480,6 +480,8 @@ raise RuntimeError('External package '+self.name+' does not work on Microsoft Windows') if self.download and self.framework.argDB.has_key('download-'+self.downloadname.lower()) and self.framework.argDB['download-'+self.downloadname.lower()] and not self.downloadonWindows and self.setCompilers.isCygwin(): raise RuntimeError('External package '+self.name+' does not support --download-'+self.downloadname.lower()+' on Microsoft Windows') + if not self.download and self.framework.argDB.has_key('download-'+self.downloadname.lower()) and self.framework.argDB['download-'+self.downloadname.lower()]: + raise RuntimeError('External package '+self.name+' does not support --download-'+self.downloadname.lower()) return Matt
Could you please add something to BuildSystem so that if a user requests --download-packagename but that functionality is not supported it generates a nice error message, in particular this needs to work for --download-thrust --download-cusp and --download-cuda but there are many others as well.
Thanks
Barry
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
