Re: [petsc-dev] MatNullSpaceDestroy
On 23 March 2011 20:09, Barry Smith <[email protected]> wrote:
On Mar 23, 2011, at 5:58 PM, Lisandro Dalcin wrote:
Are you going to rename MatNullSpaceDestroy -> MatNullSpaceDestroy_ and add the backward compatibility #define? Changeset 1a6f5fc1c27b broke petsc4py...
No, it was changed to the &object paradigm.
Basically what is happening now is that commonly used destroys are changed with the _ paradigm
Uncommonly used destroy are fixed to use the &object paradigm.
Don't like the fact that there are two paradigms well I could change everything to & immediately :-(
Barry, whatever you want to do, please be consistent :-)... The lines below are from MatNullSpaceCrete /* cannot use MatNullSpaceDestroy() as generic destroy function because it takes pointer to the object */ ierr = PetscHeaderCreate(sp,_p_MatNullSpace,int,MAT_NULLSPACE_CLASSID,0,"MatNullSpace",comm,0,0);CHKERRQ(ierr); So now MatNullSpace instances cannot be freed with PetscObjectDestroy()... This change broke bad petsc4py Python+PETSc refcounting management. BTW, PetscObjectDestroy() does not take a pointer... And IMHO PetscHeaderDestroy should also take a pointer... Barry, please, just reconsider this and make MatNullSpaceDestroy follow the same pattern as Object, IS, Vec, Mat, etc. PS: I still think all this is going to be a mess... now one commented about my previous proposal about a compatibility header. what's wrong with that? -- Lisandro Dalcin --------------- CIMEC (INTEC/CONICET-UNL) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1011) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
