Re: [petsc-dev] MacOS firewall annoyance while running tests + solution
On 29 Aug 2020, at 02:03, Hapla Vaclav <[email protected]> wrote:
On 28 Aug 2020, at 22:47, Jed Brown <[email protected]> wrote:
"Hapla Vaclav" <[email protected]> writes:
On MacOS, maybe you also have lots of firewall popups appearing/disappearing when running tests like Do you want the application "ex29" to accept incoming network connections?
Is there a way to express that the application does not need (should not accept) incoming connections?
Oh yes, hadn't thought about before, but it's surely better to _block_ the incoming connections - feels safer for a user at least.
But the way is the same, requiring sudo:
sudo /usr/libexec/ApplicationFirewall/socketfilterfw --add $PETSC_DIR/$PETSC_ARCH/tests/dm/impls/plex/tests/ex9 sudo /usr/libexec/ApplicationFirewall/socketfilterfw --block $PETSC_DIR/$PETSC_ARCH/tests/dm/impls/plex/tests/ex9
Funny enough, these commands don't fail without sudo but they have no effect.
Normalizing sudo during build/testing seems really bad.
I agree. It shouldn't be a normal part of the makefile. That's why I have been hesitant to create a MR. I think we could 1. just add an FAQ entry - but the patch can become out-of-date pretty quickly, and instructions without a patch are gonna be tedious 2. activate this part conditionally, requiring a user's action such as passing a very special variable to makefile 3. put it into a separate makefile and add a commented out include into gmakefile.test, so that the user has to explicitly uncomment the inclusion - or something like that 4. something else?
Jed, Barry, thoughts here? Thanks, Vaclav
Vaclav
participants (1)
Hapla Vaclav
