Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure
Hi, I cannot build petsc-3.6.1 on ubuntu. I am getting the error below. Is mumps broken here? I am using ubuntu trusty. make[1]: Leaving directory `petsc-3.6.1/arch-linux2-cxx-opt/externalpackages/MUMPS'mumps_io_basic.c: In function ‘mumps_init_file_name’: mumps_io_basic.c:579:14: warning: assignment discards ‘const’ qualifier from pointer target type [enabled by default] tmp_dir=MUMPS_OOC_DEFAULT_DIR; ^ cmumps_ooc.F:159.42: OOC_NB_FILE_TYPE=id%OOC_NB_FILE_TYPE 1 Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure cmumps_ooc.F:525.36: DO I1=1,id%OOC_NB_FILE_TYPE 1 Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure cmumps_ooc.F:540.12: ENDDO 1 Error: Expecting END IF statement at (1) cmumps_ooc.F:562.31: IF(.NOT. id%IF_RESTARTING) CALL CMUMPS_OOC_CLEAN_FILES(id,IERR) 1 Error: 'if_restarting' at (1) is not a member of the 'cmumps_struc' structure cmumps_ooc.F:677.42: OOC_NB_FILE_TYPE=id%OOC_NB_FILE_TYPE 1 Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure make[3]: *** [cmumps_ooc.o] Error 1 make[2]: *** [c] Error 2 make[1]: *** [mumps_lib] Error 2 make: *** [c] Error 2 *******************************************************************************
participants (1)
Chaffra Affouda
