All public API changes have to be documented at src/docs/website/documentation/changes/dev.html. http://petsc.cs.iit.edu/petsc/petsc-dev/rev/a942f19a37c9 Some questions and comments on this patch: 1. Why don't you use the API (e.g. PetscLayoutSetBlockSize()) when setting the block size? 2. What was wrong with the default MatGetVecs()? 3. Options prefixes should inherit the prefix from the parent and should end with "_" so that they aren't squashed together with the suboptions. 4. MatCreateIS() leaks the new Vec "global". 5. Why is the matrix being forced to be square? 6. Why is the size of the rmap/cmap being changed to be possibly different from m,n,M,N passed in? By not using the PetscLayout API, it looks like we can end up with a corrupt PetscLayout this way.
participants (1)
Jed Brown
