Re: [petsc-dev] c++, float128 and complex patch
This fix is now in 'balay/fix-quad-complex-from-cxx' - and merged to next. https://bitbucket.org/petsc/petsc/commits/546cf89789929e13eb602224f891fdd5ff... Satish On Wed, 6 Sep 2017, Satish Balay wrote:
So, could you give me a hint on how I should configure petsc so that this works? Is there a way to enforce the c99 complex numbers even when calling petsc from c++?
Perhaps this is the change you need?
Looks like I need one more change..
Satish
--------- balay@asterix /home/balay/petsc (master *=) $ git diff diff --git a/include/petscmath.h b/include/petscmath.h index a63f1f4977..a201c3093e 100644 --- a/include/petscmath.h +++ b/include/petscmath.h @@ -214,7 +214,7 @@ PETSC_EXTERN MPI_Datatype MPIU___COMPLEX128; #endif /* PETSC_USE_REAL_ */ #endif /* ! PETSC_SKIP_COMPLEX */
-#elif !defined(__cplusplus) && defined(PETSC_HAVE_C99_COMPLEX) && !defined(PETSC_USE_REAL___FP16) +#elif defined(PETSC_HAVE_C99_COMPLEX) && !defined(PETSC_USE_REAL___FP16) #if !defined(PETSC_SKIP_COMPLEX) #define PETSC_HAVE_COMPLEX 1 #include <complex.h> @@ -414,7 +414,7 @@ PETSC_EXTERN PetscComplex PETSC_i; */ PETSC_STATIC_INLINE PetscComplex PetscCMPLX(PetscReal x, PetscReal y) { -#if defined(__cplusplus) +#if defined(__cplusplus) && !defined(PETSC_USE_REAL___FLOAT128) return PetscComplex(x,y); #elif defined(_Imaginary_I) return x + y * _Imaginary_I;
participants (1)
Satish Balay
