Should have cc:d to petsc-dev context: clique packages metis,parmetis,elemental sources in a single bundle. So we were attempting to build them separately [from petsc configure]. Jack has extensions to metis and parmetis functionality - thats used in clique. We tried to split this out into separate -lparmetis-addons library [using parmetis public includes] so that our current -lparmetis could be used. But this doesn't work as it needs parmetis private includes. So looks like we'll have to add these extensions to the metis/parmetis tarballs we distribute [and have common metis/parmetis sources available for both petsc an clique] Satish On Fri, 31 Aug 2012, Satish Balay wrote:
On Fri, 31 Aug 2012, Jack Poulson wrote:
Also does clique also build elemental? Can we split it up aswell with MANUAL_ELEMENTAL, ELEMENTAL_INCLUDE_DIR, ELEMENTAL_LIBS options?
I will take care of all of these issues as soon as I get a chance. Clique does currently build Elemental (it sits in external/elemental). If both Clique and Elemental are both to be used in the same package, I would think it would make sense to just install Clique and use its version of Elemental. Is there a problem with this approach? It ensures compatibility.
I'll have to check this - but 2 ways of building the same thing is not easy in petsc build tools. Esp when we provide --with-elemental-dir option to configure.
Sure we'll have to make sure the compatible elemental,clique are installed - when both are installed by petsc [or by user]
Jack,
[I'm having to add the flag BUILD_PARMETIS=0.] But now I get:
cd /home/balay/spetsc/externalpackages/clique/arch-clique/src/parmetis && /usr/lib64/ccache/gcc -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 -I/home/balay/spetsc/externalpackages/clique/arch-clique/external/elemental/include -I/home/balay/soft/linux64/mpich2-1.1/include -I/home/balay/spetsc/arch-clique/include -I/home/balay/spetsc/externalpackages/clique/external/parmetis/include -I/home/balay/spetsc/externalpackages/clique/external/parmetis/libparmetis -I/home/balay/spetsc/externalpackages/clique/external/parmetis/metis/GKlib -I/home/balay/spetsc/externalpackages/clique/external/parmetis/metis/include -o CMakeFiles/parmetis-addons.dir/ParallelBisect.c.o -c /home/balay/spetsc/externalpackages/clique/src/parmetis/ParallelBisect.c /home/balay/spetsc/externalpackages/clique/src/parmetis/ParallelBisect.c:5:25: fatal error: parmetislib.h: No such file or directory
Looks like this code needs parmetis private includes. So the current stratergy [of splitting into -lparmetis-addons] isn't working.
Perhaps we'll have to use a single patched metis/parmetis tarball for both petsc and clique afterall..
Satish
participants (1)
Satish Balay
