Help with configure and cmake
11 Mar
11 Mar
'11
6:02 a.m.
I have been adding support for cmake in SLEPc. My simple approach is: 1) generate a SLEPcConfig.cmake file 2) generate CMakeLists.txt with a cmakegen module adapted from petsc-dev 3) run cmake with a cmakeboot module adapted from petsc-dev Step 3 loads RDict and uses 'script' to process all PETSc configuration. The problem comes with prefix-based installations of PETSc, since 'script' is not available. Can anyone suggest a solution for this? Maybe use Jed's FindPETSc.cmake module? Thanks. Jose
5632
Age (days ago)
5632
Last active (days ago)
0 comments
1 participants
participants (1)
Jose E. Roman
