Re: [petsc-dev] Error running on Titan with GPUs & GNU
After loading a cuda module ... On Wed, Oct 31, 2018 at 2:58 AM Mark Adams <[email protected]> wrote:
I get an error with --with-cuda=1
On Tue, Oct 30, 2018 at 4:44 PM Smith, Barry F. <[email protected]> wrote:
--with-cudac=1 should be --with-cuda=1
On Oct 30, 2018, at 12:35 PM, Smith, Barry F. via petsc-dev < [email protected]> wrote:
On Oct 29, 2018, at 8:09 PM, Mark Adams <[email protected]> wrote:
And a debug build seems to work:
Well ok.
Are there newer versions of the Gnu compiler for this system? Are there any other compilers on the system that would likely be less buggy? IBM compilers? If this simple code generates a gross error with optimization who's to say how many more subtle bugs may be induced in the library by the buggy optimizer (there may be none but IMHO probability says there will be others).
Is there any chance that valgrind runs on this machine; you could run the optimized version through it and see what it says.
Barry
21:04 1 master= /lustre/atlas/proj-shared/geo127/petsc$ make
PETSC_DIR=/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda PETSC_ARCH="" test
Running test examples to verify correct installation Using PETSC_DIR=/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda and PETSC_ARCH= *******************Error detected during compile or link!******************* See http://www.mcs.anl.gov/petsc/documentation/faq.html /lustre/atlas/proj-shared/geo127/petsc/src/snes/examples/tutorials ex19
cc -o ex19.o -c -g -I/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/include `pwd`/ex19.c cc -g -o ex19 ex19.o -L/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib -Wl,-rpath,/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib -L/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib -lpetsc -lHYPRE -lflapack -lfblas -lparmetis -lmetis -ldl
/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib/libpetsc.a(dlimpl.o): In function `PetscDLOpen':
/lustre/atlas1/geo127/proj-shared/petsc/src/sys/dll/dlimpl.c:108: warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib/libpetsc.a(send.o): In function `PetscOpenSocket':
/lustre/atlas1/geo127/proj-shared/petsc/src/sys/classes/viewer/impls/socket/send.c:108: warning: Using 'gethostbyname' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
true ex19 rm ex19.o Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process See http://www.mcs.anl.gov/petsc/documentation/faq.html lid velocity = 0.0016, prandtl # = 1., grashof # = 1. Number of SNES iterations = 2 Application 19081049 resources: utime ~1s, stime ~1s, Rss ~17112, inblocks ~36504, outblocks ~111043 Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes See http://www.mcs.anl.gov/petsc/documentation/faq.html lid velocity = 0.0016, prandtl # = 1., grashof # = 1. Number of SNES iterations = 2 Application 19081050 resources: utime ~1s, stime ~1s, Rss ~19816, inblocks ~36527, outblocks ~111043 5a6
Application 19081051 resources: utime ~1s, stime ~0s, Rss ~13864, inblocks ~36527, outblocks ~111043 /lustre/atlas/proj-shared/geo127/petsc/src/snes/examples/tutorials Possible problem with ex19_hypre, diffs above ========================================= *******************Error detected during compile or link!******************* See http://www.mcs.anl.gov/petsc/documentation/faq.html /lustre/atlas/proj-shared/geo127/petsc/src/snes/examples/tutorials ex5f
ftn -c -g -I/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/include -o ex5f.o ex5f.F90 ftn -g -o ex5f ex5f.o -L/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib -Wl,-rpath,/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib -L/lustre/atlas/proj-shared/geo127/petsc_titan_dbg64idx_gnu_cuda/lib -lpetsc -lHYPRE -lflapack -lfblas -lparmetis -lmetis -ldl
rm ex5f.o Possible error running Fortran example src/snes/examples/tutorials/ex5f with 1 MPI process See http://www.mcs.anl.gov/petsc/documentation/faq.html Number of SNES iterations = 4 Application 19081055 resources: utime ~1s, stime ~0s, Rss ~12760, inblocks ~36800, outblocks ~111983 Completed test examples 21:06 master= /lustre/atlas/proj-shared/geo127/petsc$
participants (1)
Mark Adams
