Re: [petsc-dev] What to do with DMDALocalToLocal routines when adding DMLocalToLocalBegin()/End()?
Barry, Yes, you are right. I had erroneously thought that it was a "user" routine with a manual page; I was thrown off by the nice comment at the beginning. =) --Richard On 3/27/13 11:14 PM, Barry Smith wrote:
On Mar 27, 2013, at 2:23 PM, Richard Tran Mills <[email protected]> wrote:
As mentioned previously, I want to add DMLocalToLocalBegin()/End() interface functions. This operation is only supported by DMDA right now (see src/dm/impls/da/daltol.c). It appears that I should convert DMDALocalToLocalBegin()/End() to DMLocalToLocalBegin/End_DA(). I lean towards leaving DMDALocalToLocalCreate() (which is called "lazily" by DMDALocalToLocalBegin()) as-is, however. Does this sound OK?
Likely its name should be changed to DMLocalToLocalCreate_DA() so that it is clear that it is a utility routine that is not generally to be called directly by users.
Barry
--Richard
-- Richard Tran Mills, Ph.D. Computational Earth Scientist | Joint Assistant Professor Hydrogeochemical Dynamics Team | EECS and Earth & Planetary Sciences Oak Ridge National Laboratory | University of Tennessee, Knoxville E-mail: [email protected] V: 865-241-3198 http://climate.ornl.gov/~rmills
participants (1)
Richard Tran Mills
