Re: [petsc-dev] configure error
yes - such issues [with huge attachments] shouldn't flood mailing list user mailboxes - and are best sent to petsc-maint. suggestion is to use: CC=/sw/lib/gcc4.4/bin/gcc-4 CFLAGS=-malign-double [instead of CC="/sw/lib/gcc4.4/bin/gcc-4 -malign-double"] Satish On Thu, 19 Apr 2012, Mark F. Adams wrote:
[I sent this error message but it "Your message to petsc-dev awaits moderator approval" because the configure.log was > 512 Kb???]
I'm moving to a serial build on my Mac and am getting this error:
CMake will not be able to correctly generate this project. Call Stack (most recent call first): CMakeLists.txt:2 (project)
CMake Error: your C compiler: "/sw/lib/gcc4.4/bin/gcc-4 -malign-double" was not found. Please set CMAKE_C_COMPILER to a valid compiler path or name. *******************************************************************************
~/Codes/petsc-dev-merge> ~/Codes/petsc-dev-merge>ll /sw/lib/gcc4.4/bin/gcc-4 lrwxr-xr-x 1 root admin 30 Jan 7 2011 /sw/lib/gcc4.4/bin/gcc-4 -> /sw/lib/gcc4.4/bin/gcc-fsf-4.4 ~/Codes/petsc-dev-merge>ll /sw/lib/gcc4.4/bin/gcc-fsf-4.4 -rwxr-xr-x 3 root admin 305400 Jan 7 2011 /sw/lib/gcc4.4/bin/gcc-fsf-4.4
participants (1)
Satish Balay
