Re: [petsc-dev] Backend independent VecGetArray for GPUs
On 27 October 2014 04:13, Ashwin Srinath <[email protected]> wrote:
Matthew, I think this fixes the scalar issue:
https://github.com/ashwinsrnth/petsc-pycuda/commit/145b5f138ecbdddf3c8a2ab4c...
OK, this is my proposal. We should split this code in two parts: 1) petsc4py will provide a method Vec.getCUDAAddress() that will return a plain Python integer (and a corresponding restoreCUDAAddress()). Any other name to suggest? Using "CUDAArray" would be a bit misleading in Python land. 2) With the address as a Python Integer users can use PyCUDA to build an GPUArray instance by themselves in pure Python code. Rationale: I do not want to introduce a dependency on PyCUDA in petsc4py. Moreover, users could potentially use the addresses with other tools (like ctypes or cffi, or SWIG wrappers that pass GPU pointers around). Does it make sense for all of you? -- Lisandro Dalcin ============ Research Scientist Computer, Electrical and Mathematical Sciences & Engineering (CEMSE) Numerical Porous Media Center (NumPor) King Abdullah University of Science and Technology (KAUST) http://numpor.kaust.edu.sa/ 4700 King Abdullah University of Science and Technology al-Khawarizmi Bldg (Bldg 1), Office # 4332 Thuwal 23955-6900, Kingdom of Saudi Arabia http://www.kaust.edu.sa Office Phone: +966 12 808-0459
participants (1)
Lisandro Dalcin
