Has anyone tried the Matlab interface with petsc-dev? If I run exKSP.m three consecutive times, the first time it runs ok, the second time I see a memory leak (see below) and after that I get an error (with exKSP or any other one). This was not happening in 3.3. Also, some scripts are out-of-date. It is necessary to add mat.SetUp() and other minor fixes. Jose
exKSP Vector Object: 1 MPI processes type: seq 12.5 14.5 3 4 5 6 7 8 9 10 Matrix Object: 1 MPI processes type: seqaij row 0: (0, 10) row 1: (1, 10) row 2: (2, 10) row 3: (3, 10) row 4: (4, 10) row 5: (5, 10) row 6: (6, 10) row 7: (7, 10) row 8: (8, 10) row 9: (9, 10) 0 KSP Residual norm 2.732215218463e+00 1 KSP Residual norm 1.516684121884e-16 Vector Object: 1 MPI processes type: seq 1.25 1.45 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 KSP Object: 1 MPI processes type: gmres GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement GMRES: happy breakdown tolerance 1e-30 maximum iterations=10000, initial guess is zero tolerances: relative=1e-05, absolute=1e-50, divergence=10000 left preconditioning using PRECONDITIONED norm type for convergence test PC Object: 1 MPI processes type: ilu ILU: out-of-place factorization 0 levels of fill tolerance for zero pivot 2.22045e-14 using diagonal shift on blocks to prevent zero pivot matrix ordering: natural factor fill ratio given 1, needed 1 Factored matrix follows: Matrix Object: 1 MPI processes type: seqaij rows=10, cols=10 package used to perform factorization: petsc total: nonzeros=10, allocated nonzeros=10 total number of mallocs used during MatSetValues calls =0 not using I-node routines linear system matrix = precond matrix: Matrix Object: 1 MPI processes type: seqaij rows=10, cols=10 total: nonzeros=10, allocated nonzeros=50 total number of mallocs used during MatSetValues calls =0 not using I-node routines [0]Total space allocated 4880 bytes [ 0]16 bytes PetscThreadCommReductionCreate() line 448 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommReductionCreate() line 448 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommWorldInitialize() line 1251 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]512 bytes PetscThreadCommReductionCreate() line 440 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommReductionCreate() line 440 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommWorldInitialize() line 1251 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]128 bytes PetscThreadCommReductionCreate() line 436 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommReductionCreate() line 436 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommWorldInitialize() line 1251 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]1280 bytes PetscThreadCommReductionCreate() line 435 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommReductionCreate() line 435 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommWorldInitialize() line 1251 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]32 bytes PetscThreadCommReductionCreate() line 432 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommReductionCreate() line 432 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcommred.c [0] PetscThreadCommWorldInitialize() line 1251 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]64 bytes PetscThreadCommWorldInitialize() line 1265 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommWorldInitialize() line 1265 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]2432 bytes PetscThreadCommWorldInitialize() line 1264 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommWorldInitialize() line 1264 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]16 bytes PetscThreadCommWorldInitialize() line 1256 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommWorldInitialize() line 1256 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]16 bytes PetscThreadCommSetAffinities() line 423 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommSetAffinities() line 423 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommWorldInitialize() line 1251 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]48 bytes PetscThreadCommCreate() line 150 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommCreate() line 150 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommWorldInitialize() line 1251 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]320 bytes PetscThreadCommCreate() line 146 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommCreate() line 146 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscThreadCommWorldInitialize() line 1251 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscGetThreadCommWorld() line 80 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommGetThreadComm() line 114 in /Users/jroman/soft/petsc/src/sys/threadcomm/interface/threadcomm.c [0] PetscCommDuplicate() line 139 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c [ 0]16 bytes PetscCommDuplicate() line 151 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscCommDuplicate() line 151 in /Users/jroman/soft/petsc/src/sys/objects/tagm.c [0] PetscHeaderCreate_Private() line 31 in /Users/jroman/soft/petsc/src/sys/objects/inherit.c [0] VecCreate() line 32 in /Users/jroman/soft/petsc/src/vec/vec/interface/veccreate.c exKSP [0]PETSC ERROR: --------------------- Error Message ------------------------------------ [0]PETSC ERROR: Invalid argument! [0]PETSC ERROR: Wrong type of object: Parameter # 2! [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Petsc Development GIT revision: 854e096b3f56ee49eddbdee02830d60adb46893b GIT Date: 2013-04-03 20:53:18 -0500 [0]PETSC ERROR: See docs/changes/index.html for recent updates. [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting. [0]PETSC ERROR: See docs/index.html for manual pages. [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: matlab on a arch-darwin-c-debug-matlab named pptp243-73.vpns.upv.es by jroman Fri Apr 5 17:49:20 2013 [0]PETSC ERROR: Libraries linked from /Users/jroman/soft/petsc/arch-darwin-c-debug-matlab/lib [0]PETSC ERROR: Configure run at Fri Apr 5 17:31:03 2013 [0]PETSC ERROR: Configure options --with-matlab --with-matlab-engine --with-mpi=0 [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: VecView() line 682 in /Users/jroman/soft/petsc/src/vec/vec/interface/vector.c ??? Error using ==> PetscCHKERRQ at 3 Errors generated on calling Petsc library function
Error in ==> PetscVec>PetscVec.View at 106 err = calllib('libpetsc', 'VecView', obj.pobj,0);PetscCHKERRQ(err); Error in ==> PetscVec>PetscVec.subsref at 123 [varargout{1:nargout}] = builtin('subsref', obj, S); Error in ==> exKSP at 18 b.View;
participants (1)
Jose E. Roman
