Re: [petsc-dev] kokkos test fail in branch
This problem was fixed in https://gitlab.com/petsc/petsc/-/merge_requests/4056, and is waiting for !3411 <https://gitlab.com/petsc/petsc/-/merge_requests/3411> :) --Junchao Zhang On Sat, Jun 5, 2021 at 9:42 PM Barry Smith <[email protected]> wrote:
Looks like the MPI libraries are not being passed to the NVCC internal compiler (gcc). This would normally be setup in MPI.py, please send configure.log
Barry
On Jun 5, 2021, at 1:18 PM, Mark Adams <[email protected]> wrote:
Ah, there was an old one there. I removed it and I can not compile ex3k. I thought check always rebuilt executables. Now I get a link error:
14:12 barry/2020-11-11/cleanup-matsetvaluesdevice *= /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials$ make PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 ex3k
PATH=/sw/sources/lsf-tools/2.0/summit/bin:/sw/summit/xalt/1.2.1/bin:/sw/summit/forge/20.0.1/bin:/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/bin:/sw/summit/gcc/6.4.0/bin:/sw/summit/cuda/10.1.243/bin:/autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/cmake-3.20.2-24ualfzy6em6ws5sbiu7rlgcuionodrm/bin:/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/darshan-runtime-3.1.7-cnvxicgf5j4ap64qi6v5gxp67hmrjz43/bin:/sw/sources/hpss/bin:/opt/ibm/spectrumcomputing/lsf/ 10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/etc:/opt/ibm/spectrumcomputing/lsf/10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/bin:/opt/ibm/csm/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/ibm/flightlog/bin:/opt/ibutils/bin:/opt/ibm/spectrum_mpi/jsm_pmix/bin:/opt/puppetlabs/bin:/usr/lpp/mmfs/bin:`dirname <http://10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/etc:/opt/ibm/spectrumcomputing/lsf/10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/bin:/opt/ibm/csm/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/ibm/flightlog/bin:/opt/ibutils/bin:/opt/ibm/spectrum_mpi/jsm_pmix/bin:/opt/puppetlabs/bin:/usr/lpp/mmfs/bin:%60dirname> nvcc` NVCC_WRAPPER_DEFAULT_COMPILER=gcc /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/bin/nvcc_wrapper --expt-extended-lambda -Xcompiler -rdynamic -lineinfo -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4 -Xcompiler -fPIC -O3 -gencode arch=compute_70,code=sm_70 -I/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/include -Wno-deprecated-gpu-targets -I/gpfs/alpine/csc314/scratch/adams/petsc/include -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include -I/sw/summit/cuda/10.1.243/include -I/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/include -fPIC -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4 -Werror=maybe-uninitialized -O0 ex3k.kokkos.cxx -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib -L/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/netlib-lapack-3.8.0-wcabdyqhdi5rooxbkqa6x5d7hxyxwdkm/lib64 -Wl,-rpath,/sw/summit/cuda/10.1.243/lib64 -L/sw/summit/cuda/10.1.243/lib64 -lpetsc -lkokkoskernels -lkokkoscontainers -lkokkoscore -lp4est -lsc -lblas -llapack -ltriangle -lm -lz -lcudart -lcufft -lcublas -lcusparse -lcusolver -lcurand -lstdc++ -ldl -o ex3k nvcc_wrapper - *warning* you have set multiple optimization flags (-O*), only the last is used because nvcc can only accept a single optimization setting.
*/usr/bin/ld: /tmp/tmpxft_0000e0c2_00000000-10_ex3k.kokkos.o: undefined reference to symbol 'ompi_mpi_comm_self'*/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/lib/libmpi_ibm.so.3: error adding symbols: DSO missing from command line collect2: error: ld returned 1 exit status make: *** [ex3k] Error 1
On Sat, Jun 5, 2021 at 12:16 PM Junchao Zhang <[email protected]> wrote:
$rm ex3k $make ex3k and run again?
--Junchao Zhang
On Sat, Jun 5, 2021 at 10:25 AM Mark Adams <[email protected]> wrote:
This is posted in Barry's MR, but I get this error with Kokkos-cuda on Summit. Failing to open a shared lib. Thoughts? Mark
11:15 barry/2020-11-11/cleanup-matsetvaluesdevice= /gpfs/alpine/csc314/scratch/adams/petsc$ make PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 check Running check examples to verify correct installation Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes C/C++ example src/snes/tutorials/ex19 run successfully with cuda gmake[3]: [runex3k_kokkos] Error 127 (ignored) 1,25c1,2 < atol=1e-50, rtol=1e-08, stol=1e-08, maxit=50, maxf=10000 < Vec Object: Exact Solution 2 MPI processes < type: mpikokkos < Process [0] < 0. < 0.015625 < 0.125 < Process [1] < 0.421875 < 1. < Vec Object: Forcing function 2 MPI processes < type: mpikokkos < Process [0] < 1e-72 < 1.50024 < 3.01563 < Process [1] < 4.67798 < 7. < 0 SNES Function norm 5.414682427127e+00 < 1 SNES Function norm 2.952582418265e-01 < 2 SNES Function norm 4.502293658739e-04 < 3 SNES Function norm 1.389665806646e-09 < Number of SNES iterations = 3 < Norm of error 1.49752e-10 Iterations 3 ---
*> ./ex3k: error while loading shared libraries: libpetsc.so.3.015: cannot open shared object file: No such file or directory> ./ex3k: error while loading shared libraries: libpetsc.so.3.015: cannot open shared object file: No such file or directory* /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials
participants (1)
Junchao Zhang
