Re: [petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
On Thu, 7 Jun 2012, Jed Brown wrote:
On Thu, Jun 7, 2012 at 3:30 PM, Satish Balay <[email protected]> wrote:
subrepository sources for config/BuildSystem differ use (l)ocal source (eadaa286b5ca) or (r)emote source (6ab6f1ae4aff)?
Ok - I have to choose 'r' here for what I want [wrt diff/auto-merge].
[balay@maverick petsc-buildsystem-dev]$ hg stat -S M .hgsubstate M config/BuildSystem/config/packages/BlasLapack.py M config/examples/asterix/asterix64.py [balay@maverick petsc-buildsystem-dev]$
But for some reason '.hgsubstate' is not updated [to correspond to 'hg pull -u' version].
Had you changed the .hgsub?
Nope.
In any case, the right solution when there is a conflict in BuildSystem is always to go into BuildSystem and resolve it (by merging or rebasing), then commit the result to the petsc repository.
This is a usage without commits - only local changes/edits - and then 'pull -u'
As for the (now long past) request for implicitly tracking the latest versions of subrepos, this quote from Matt Mackall is apropos.
*We're always telling people "no, subrepos are NOT for automatically getting the latest versions of other projects, that's not Version Controlâ„¢"*
Sure - but I'm trying to understand all the extra control flow paths that come up with subrepos. Also the above case doesn't fall in the category of 'automatically getting the latest version of other projects' Satish
participants (1)
Satish Balay
