Re: [petsc-dev] Not possible to do a VecPlaceArray for veccusp
El 28 feb 2016, a las 10:45, Karl Rupp <[email protected]> escribió:
I like the idea of having separate VECCUDA and VECVIENNACL, because it is possible to implement VECCUDA without dependence on a C++ compiler (only the CUDA compiler).
I don't understand this part. NVCC also requires a C++ host compiler and is fairly picky about the supported compilers.
You are right. I was thinking of the case when one has a pure C code and wants to use a --with-language=C PETSc configuration.
If you want, we can prepare a rough initial implementation of VECCUDA in the next days, and we can later discuss what to keep/discard.
Any contributions are welcome :-)
Karl: regarding the time constraints, our idea is to present something at a conference this summer, and deadlines are approaching.
Ok, this is on fairly short notice considering the changes required. I recommend to start with copying the CUSP sources and migrate it over to VECCUDA by replacing any use of cusp::array1d to a raw CUDA handle. Operations from CUSP should be replaced by CUBLAS calls.
Ok. Will start work on this. Jose
Best regards, Karli
participants (1)
Jose E. Roman
