Re: [petsc-dev] patches for ICC/Cholesky preconditioner on GPUs
Jed, I think I've resolved all of your comments. I have some questions. 1) Tests for the nightly test harness (a) Is there a naming convention for the tests? I have written two examples named aijcusparse_ex_ilu.c and aijcusparse_ex_icc.c. Is this ok? (b) What directory should they live in? I assume these go in ksp/ksp/examples/tutorials (c) How do I ensure that they tests are built and run every night with txpetscgpu package? (d) Where do I put binary matrix files that these tests rely upon? 2) Doing
git status shows Your branch is ahead of 'origin/pm/aijcusparse-icc' by 2 commits.
I assume that when I push to the fork, these changes will be uploaded remotely? Thanks, -Paul
Paul Mullowney<[email protected]> writes:
I've gotten GPU based icc preconditioners working with the following set of patches. One uses ICC by loading an upper triangular matrix into the cusparse class, and then setting the symmetry option, i.e.
ierr = MatCreateSeqAIJCUSPARSE(comm,n,m,PETSC_NULL,num_entries_per_row,&A);CHKERRQ(ierr); ierr = MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE);
I've organized the implementations into 2 files: 1) icc-cholesky-cusparse-organization.patch : This patch has the basic infrastructure for calling the symbolic and numeric factorizations (both ICC and Cholesky). Currently these routines make scoping calls to the implementations in aij/seq/aijfact.c Can you write context like this into the commit messages? They are pretty opaque right now, but they are more likely to be read in the future than this email.
This patch series does not have any tests. Can you add tests so that we can have a reasonable chance of not breaking it in the future?
We can review on the mailing list, but I think we would prefer to use pull requests, mostly because comments there sort by context rather than by author. Barry, Matt, and others, do you prefer the granularity of email or bitbucket comments?
A few comments now:
exporting patch: This first line should not be in the patch file. It should start with the lines below:
# HG changeset patch # User Paul Mullowney<[email protected]> # Date 1362859983 25200 # Node ID 6be0d0f06ad18794377015b5ec468e11105b58b1 # Parent 6d60df3aadfe49f0bf640fa0a41fe3a423b88cf6 Implementation of ICC in this patch. Include the component (aijcusparse) in the commit message, otherwise we don't have a clue from the commit message what is actually being done.
diff -r 6d60df3aadfe -r 6be0d0f06ad1 src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu --- a/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu Mon Feb 04 11:42:47 2013 -0700 +++ b/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu Sat Mar 09 13:13:03 2013 -0700 @@ -1,12 +1,13 @@ /* - Defines the basic matrix operations for the AIJ (compressed row) + Defines the basic matrix operations for the AIJ (compressed row) matrix storage format. */
#include "petscconf.h" PETSC_CUDA_EXTERN_C_BEGIN #include "../src/mat/impls/aij/seq/aij.h" /*I "petscmat.h" I*/ -//#include "petscbt.h" +#include<../src/mat/impls/sbaij/seq/sbaij.h> + #include "../src/vec/vec/impls/dvecimpl.h" #include "petsc-private/vecimpl.h" PETSC_CUDA_EXTERN_C_END Not part of this patch, but PETSC_CUDA_EXTERN_C_BEGIN/END should be replaced with appropriate use of PETSC_EXTERN (as shown below). We are no longer mangling any public function names, so we can now compile PETSc using --with-clanguage=C++ and then call it from plain C.
@@ -53,12 +54,28 @@ EXTERN_C_BEGIN extern PetscErrorCode MatGetFactor_seqaij_petsc(Mat,MatFactorType,Mat*); EXTERN_C_END Use this instead:
PETSC_EXTERN PetscErrorCode MatGetFactor_seqaij_petsc(Mat,MatFactorType,Mat*);
@@ -404,12 +417,119 @@
+ + Isn't this a lot of blank lines?
+#undef __FUNCT__ +#define __FUNCT__ "MatSeqAIJCUSPARSEBuildICCTriMatrices" +PetscErrorCode MatSeqAIJCUSPARSEBuildICCTriMatrices(Mat A) Please use 'static' if the function is really only used in this one file. This identifier is more than 31 characters, thus too long for a public symbol.
+{ + Mat_SeqAIJ *a = (Mat_SeqAIJ*)A->data; + Mat_SeqAIJCUSPARSETriFactors *cusparseTriFactors = (Mat_SeqAIJCUSPARSETriFactors*)A->spptr; + GPU_Matrix_Ifc * cusparseMatLo = (GPU_Matrix_Ifc*)cusparseTriFactors->loTriFactorPtr; + GPU_Matrix_Ifc * cusparseMatUp = (GPU_Matrix_Ifc*)cusparseTriFactors->upTriFactorPtr; Either line up consecutive lines or don't, but don't go half way. PETSc style guide says 'type *ptr', not 'type * ptr'.
+ cusparseStatus_t stat; + PetscErrorCode ierr; + PetscInt *AiUp, *AjUp; + PetscScalar *AAUp; + PetscScalar *AALo; + PetscInt nzUpper=a->nz,n=A->rmap->n,i,offset,nz,j; + Mat_SeqSBAIJ *b = (Mat_SeqSBAIJ*)A->data; + const PetscInt *ai=b->i,*aj=b->j,*vj; + const MatScalar *aa=b->a,*v; Again, line up or don't line up.
+ /* set this flag ... for performance logging */ + ((Mat_SeqAIJCUSPARSETriFactors*)A->spptr)->isSymmOrHerm = PETSC_TRUE; Does this have a MatSetOption() interface?
#undef __FUNCT__ #define __FUNCT__ "MatSeqAIJCUSPARSEICCAnalysisAndCopyToGPU" PetscErrorCode MatSeqAIJCUSPARSEICCAnalysisAndCopyToGPU(Mat A) This can have static linkage, right?
@@ -706,8 +848,28 @@ ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr); [Different patch] PETSC_COMM_WORLD cannot be used outside of global registration.
participants (1)
Paul Mullowney
