Re: [petsc-dev] MatCreateVecs interface
On Thu, Jun 25, 2015 at 12:32 PM, Stefano Zampini <[email protected]
wrote:
pushed a fix
https://bitbucket.org/petsc/petsc/commits/ae287a2e7a141494f7c41f9dd537addb63...
However, it appears that the functions below for CUSP, CUSPARSE and VIENNACL are mere copies of the interface. What about defining the type of the Vec in the interface and get rid of these?
I think the point here is that the matrix should return Vecs of a compatible type, not a user specified one. Matt
src/mat/impls/aij/mpi/mpicusp/mpiaijcusp.cu: A->ops->getvecs = MatCreateVecs_MPIAIJCUSP; src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.cu: A->ops->getvecs = MatCreateVecs_MPIAIJCUSPARSE; src/mat/impls/aij/mpi/mpiviennacl/mpiaijviennacl.cxx: A->ops->getvecs = MatCreateVecs_MPIAIJViennaCL; src/mat/impls/aij/seq/seqcusp/aijcusp.cu: B->ops->getvecs = MatCreateVecs_SeqAIJCUSP; src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu: B->ops->getvecs = MatCreateVecs_SeqAIJCUSPARSE; src/mat/impls/aij/seq/seqviennacl/aijviennacl.cxx: B->ops->getvecs = MatCreateVecs_SeqAIJViennaCL;
Stefano
On Jun 25, 2015, at 4:34 PM, Barry Smith <[email protected]> wrote:
I think you are right, go ahead and make a pull request or send a patch
Barry
On Jun 25, 2015, at 9:43 AM, Stefano Zampini <[email protected]> wrote:
Why the current interface in MatCreateVecs requires that a matrix has been already either allocated or setup ? Shouldn’t be enough to check if the layout has been already setup?
Stefano
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
