On Fri, Aug 27, 2021 at 11:01 AM Satish Balay <[email protected]> wrote:
Perhaps 'git branch --unset-upstream' got invoked somehow?
You can check .git/config to see if you have an entry:
[branch "adams/landau-multiple-grids"] remote = origin merge = refs/heads/adams/landau-multiple-grids <<<
If not - you can fix by:
git branch -u origin/adams/landau-multiple-grids
that worked. I think I may have forgotten -u and did: git push origin +adams/landau-multiple-grids Thanks, Mark
Satish
On Fri, 27 Aug 2021, Mark Adams wrote:
I have a branch with and MR in the repo, but my branch does not seem to know it is on origin:
(base) 10:42 *adams/landau-multiple-grids* ~/Codes/petsc$ git status On branch adams/landau-multiple-grids Untracked files: (use "git add <file>..." to include in what will be committed) src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu.bak ...
There is no "=" in the prompt and no, eg, "Your branch is up to date with 'origin/adams/landau-ex2-gpu-paper'."
There seems to be something wrong with this branch. Any idea what is wrong?
Thanks, Mark
participants (1)
Mark Adams
