Re: [petsc-dev] checkbadSource issue
https://gitlab.com/petsc/petsc/-/merge_requests/3532 <https://gitlab.com/petsc/petsc/-/merge_requests/3532> attempts to remove bash specific syntax from checkbadSource.
On Dec 31, 2020, at 3:18 AM, Jose E. Roman <[email protected]> wrote:
I am getting the same in some machines. I don't think this is due to a recent change.
In the pipeline, it is run as $ make checkbadSource SHELL=bash which solves the issue.
On the other hand, in the 'checksource' job in the pipelines, there are errors (probably not important): gmakefile.test:100: arch-linux-c-debug/tests/testfiles: No such file or directory gmakefile:67: arch-linux-c-debug/lib/petsc/conf/files: No such file or directory
Jose
El 31 dic 2020, a las 9:30, Stefano Zampini <[email protected]> escribió:
Just rebased my MR over master
zampins@vulture:~/Devel/petsc$ make checkbadSource /bin/sh: 1: let: not found /bin/sh: 2: [: -gt: unexpected operator /bin/sh: 6: test: Illegal number: ! /home/zampins/Devel/petsc/lib/petsc/conf/rules:660: recipe for target 'checkbadSource' failed make[1]: *** [checkbadSource] Error 2 GNUmakefile:17: recipe for target 'checkbadSource' failed make: *** [checkbadSource] Error 2
-- Stefano
participants (1)
Barry Smith
